Possible gas leak in the range? The natural gas company says the pipeline is free of leak.
  • 563 Answers
Get an independent range service person. It is not the business of the natural gas company to service your range. So its better to be safe!
Posted on Nov 12, 2009
Is there a 210,00 gal oil spill in S. Dakota>
yes there is
Keystone pipeline leaks 210K gallons of oil in South Dakota - ABC News
abcnews.go.com/.../keystone-pipeline-leaks-210k-gallons-oil-south-dakota-51208130
1 day ago - s Keystone pipeline leaked an estimated 210,000 gallons of oil onto agricultural ... A leak and spill in southeastern South Dakota in April 2016 ...
Keystone Pipeline leaks 210,000 gallons of oil in South Dakota - CNN
www.cnn.com/2017/11/16/us/keystone-pipeline-leak/index.html 9 hours ago - A total of 210000 gallons of oil leaked Thursday from the Keystone ... This is the largest Keystone oil spill to date in South Dakota, Walsh said.
Keystone pipeline leak spills 210,000 gallons of oil in South Dakota ...
https://www.cbsnews.com/.../keystone-pipeline-leak-spills-210k-gallons-of-oil-in-sout... 1 day ago - Last Updated Nov 16, 2017 9:13 PM EST. AMHERST, S.D. -- TransCanada Corp.'s Keystone pipeline has been shut down after it leaked an ... 210 00 gal oil spill in Dakota Google Search
Nov 18, 2017 | Cars & Trucks
How do PCBs get into natural gas pipelines?
Sources of PCBs in Natural Gas Sector: PCBs are most likely to be found in equipment associated with the processing of the natural gas (Phase 3). For example, old transformers and capacitors, other electrical equipment including voltage regulators, switches, reclosers, bushings, and electromagnets, oil used in motors and hydraulic systems at gas processing plants. In addition, major interstate natural gas pipelines transport natural gas from production areas to local distribution companies (LDCs) that distribute the natural gas to industrial and urban customers. PCBs were used in turbine and air compressors as a hydraulic/lubricant and a plug valve sealant by some large interstate natural gas transmission pipeline companies and by some smaller LDCs. Some interstate pipeline companies may also have had PCB transformers and/or PCB capacitors at large compressor stations and/or maintenance facilities. Similarly, old gathering lines, which move gas from the well/well field to the gas processing plants, might also have compression stations that contain legacy PCBs.
Jul 14, 2016 | Smeg Repair Pcb / Module Dw1612 Dwi612c
start at the drill area and work back
gas at a depth behave differently than when being piped from the field
so will have all sorts of contaminates not just pcbs
when you get time.. to do a crash coarse on geology of a gas field
the gas is extracted from naturally formed (lets say gaps )
between certain types of the rock formations or layers
that is able to keep natural gas fields contained
can also be from a contaminated water table within the path of the drill hole
Jun 17, 2016 | Indesit Repair Pcb / Module Widl102
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
Jul 28, 2013 | Maytag MGR5752BDS Stainless Steel Gas...
I have a ge gas stove and the flames are are coming up real high and they r yellow and then in a few minet it shuts off i think it gets to hot but the flames r yellow on the ends dont have money to get...
You may have a failed regulator and in some cases, there is one external to the range and a second one inside the stove itself. The yellow flame indicates poor combustion so make sure you have some ventilation if you continue to use it without having it check.
If you are using city gas, call them and tell them of the problem. I think all municipal gas companies will send a service tech at no charge to avoid problems for which they might be held liable.
You should also try to give us as much detail as possible such as:
- Natural gas (and where from; well or pipeline/city) or - Propane
Jan 31, 2011 | GE Kitchen Ranges
Whirlpool model SF385PEEQ0 Gas stove was on Natural gas we have propane is there an adj or part needed as burns yellow flame!
You need to adapt your range for the propane gas. You need to change the orifices, propane needs a larger opening than natural gas. If you contact your propane company they can help you and some will even do it as a free service (or used to).
Jun 18, 2010 | Whirlpool SF325 Gas Kitchen Range
It take my oven over an hour to heat up to 350. The gas burners work fine. It has always been slow to heat up but has been getting slower. It's about 6 years old.
Hi, is it possible that your oven was never converted from LPG to Natural gas? That would explain your symptoms. Without seeing the cooktop burners, I can't say if they are set for proper output. In my area, the gas company will come out check operation of any gas appliances, for free. If you use Propane, sorry. Comment back if my idea sounds plausible or if you can't get the gas company to come out.
Jan 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
57 people viewed this question
k24674
jasbo
jasbo
