Kenwood ka-3500 does you know the sub for nec 616b and nec 588 transistors or at least the specs. Thanks
  • chiefkenny Jan 09, 2008
    is the newark part # 24b9320 a sub for both the nec616b and the nec 588? thanks
Newark Part Number: 24B9320
Posted on Jan 09, 2008
Is it possible to connect a sub woofer to a Kenwood KA 4010 amplifier ?
Only if the AMP's output section has a sub woofer connection point.
Dec 08, 2016 | Kenwood Car Audio & Video
I have a kenwood ka-94 and it still plays music but if I turn the volume up the speakers start making a popping noise and the speakers are not the problem so I need to know what the problem could be...
It does sound like your speakers. But it could be the output transistor are going bad. As you increase the volume causing more current to go thru them it make a clipping sound. If you have a different set of speaker try and see if the popping is replicated. If not have some check your receiver out.
Oct 20, 2013 | Kenwood Audio Players & Recorders
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
The model number is Kenwood KA-894 integrated Amplifier I'm trying to find out how many watts. Thanks
The manual with 'specs' is here. Take them with a grain of salt because it's impossible to produce more audio watts than are consumed electrically (250 total).
http://www.retrevo.com/s/Kenwood-KA-894-Amps-review-manual/id/479ag211/t/1-2/
Dec 25, 2010 | Audio Players & Recorders
**** speakercraft!
Can you post the markings on the transistors themselves? I will look up what I can and try to get you a more common substitute. Post what eve information you can about the transistors and I'll see what I can find. The model and the output specs that are published for the unit would help too. Thanks, Dan
Jun 06, 2009 | SpeakerCraft BassX-10 Subwoofer
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
Kenwood kac-7202 wirng 4 subs
look at the Z [impedance] specs for the amp. Look at the Z for the speakers. You may eventually have to wire them in a series-parallel config or risk blowing your output transistors.
Due to the utilization of so many drivers, your power demands are limited. The more drivers you utilize, the more volume loss. Bass response requires a lot of power (W) in which to drive.
Do not worry about paper or polyprop/carbonate structures... focus on your impedance issue or risk frying the output transistors in the long run [thermal runaway].
Oct 15, 2008 | Kenwood KAC-7202 Car Audio Amplifier
I have a kenwood KA 1060 amp, and recently changed the fuse on the first PCB board where the mains power lead connects to the unit as the fuse had blown. After doing so and testing it again the fuse has...
Most likely the output transistors are shorted. This causes the output stage to draw too much current and blows the fuses. Expect a parts cost around $20-$40. Add in the local labor rate for the total repair cost.
Dan
Apr 17, 2008 | Audio Players & Recorders
Kenwood system with tuner, cd player, casette player,intregrated amplifier and stereo power amplifier
This website sells the owners manual for $9.99 and the service manual for $14.99 your stereo:
Here is the website:
http://www.user-manuals.com/advanced_search_result.php?keywords=KA-996&x=11&y=15
Hope this helps.
Could be too many different reasons for no/low output. My 1st guess would be the output transistors, but that again is guessing without knowing more info about the receiver.
Hopefully, its is something simple like the way it's hooked up, or if you have the wrong channel selected.
Good luck.
Feb 02, 2008 | Audio Players & Recorders
256 people viewed this question
 Grubhead
Grubhead
