Question about Cell Phones
On the inside of my LG en V2 wireless phone, there is a blue bar. On this blue bar a wireless phone has shown up as well as the sound icon. What does this mean?
I get picture on Viber laptop, but no sound. How do I get speakers to work and where can I find the speakers.
Check to see if you a speaker icon in the lower r/h side of the task-bar down by the clock.
If the icon is not there right click on a blank area of the task-bar and left click 'properties'
Left click 'customize'
Scroll down to 'Volume' and select 'Show icon and notifications "
Click 'OK'
Close the 2 properties pop-ups.
Right click on the speaker icon and select 'playback devices'
The 'sound' pop up will appear showing whatever you have connected ( speakers or headset etc)
Make sure the speakers are set as default if you have more than one sound device connected.
The speakers should have a green tick (check ) when they are ready to use
Right click on the speaker icon and select 'Open volume mixer"
Check that the volume slider is above 50% and the speakers are not muted (shown as a red no-entry sign on the speaker icons at the bottom of the sliders' If muted click on the slider speaker icon.
Right click on the speaker icon and select 'playback devices' Put the cursor on the blue graph to the right of the icon, right click and select 'test' All being well the computer speakers will respond.
Dec 03, 2016 | Cell Phones
Connect LG NB3520A to Fisher RS-625 receiver
You would have to install a speaker selection switch. You cannot directly hook up 2 amplifiers to one set of speakers without destroying one or both amplifiers. Unfortunately, one set of amplifiers is inside your sound bar. An external switch would have to be installed on your sound bar as well as speaker terminals that would connect to your Fisher.
If you have a line out or tape out on your Fisher, and you have an analog input on your sound bar, use could use that as an alternate solution. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | LG NB3520A 300W Sound Bar with Wireless...
Icons on the home page
Tap the white-on-blue up-arrow near the lower-left corer of the screen, then drag the unwanted icons to the icon bar at the bottom of the screen. When done, tap the white-on-blue down-arrow at the upper-left corner.
Bear in mind that not all icons can be removed from the home screen.
Aug 26, 2012 | Lg800g With 1200 Minutes And TripMinutes...
My LG Optimus L3 e400 is set for a foreign language. How do I change it to english
GO TO SETTINGS THEN MOVE DOWN FROM,, WIFI ICON,THEN TELEPHONE ICON, THEN SOUND ICON, THEN SUNLIGHT ICON, THEN HOME ICON,, THEN ANDROID ICON , THEN RECYCLE ICON, THEN FENCE ICON, THEN SD ICON, THEN NEXT TO IT IS THE "Aa" INSIDE A RED BOX ICON,, PRESS ON IT.. AND THERE YOULL HAVE LANGUAGE OPTIONS,,
Jun 12, 2012 | LG Cell Phones
I turned my LG GD510 off earlier then put it on the charge as it had two bars of charge left but when i went to turn it on it wouldn't even if i put it on charge and ive tried everything
It happens sometimes. The bars that are shown are false. So you should check whether you really have the charge or not . just switch on the music player for two minutes and it will show you the original charge remaining on the icon.
Feb 26, 2011 | LG GD510 Cell Phone
Wireless router no longer working.
yellow icon mean that you have not assigned any ip address to your laptop also router is not assigning the ip to laptop automatically...do one thing. either assign ip manually by right clking on network icon shown near clock click status>>>clk properties>>>select internet protocol (tcp ip)>>>clk properties and add ip address as follow
ip==>> 192.168.1.100
subnet mask>>255.255.255.0
gateway>>192.168.1.1
clk ok ok ok
or you can reset your router to factory default by looking for a small button on the router.... keep pressing the button as all lights on router together flick for once.....do reply back
Nov 11, 2009 | NetGear WGT624 Wireless Router
Unlock phone
*22899 will reset it to the last four of the phone number
otherwise take it to the store and have a rep hook it to the PST machine where they will be able to give you the lock code. (but only the knowledgeable reps will be able to do this, and at verizon those are hard to come by)
Nov 05, 2009 | Cell Phones
Lost my book
Go to www.gsmarena.com and select your phone model. On the webpage of specs you will find an option for User Guide. from here you can download your User Guide in PDF format. Free.
Aug 06, 2009 | LG CU400 Cellular Phone
Strange icon on phone display
sounds like your bluetooth icon.
goto: menu....setting and tools......bluetooth.....
then there should be an option to turn bluetooth power OFF. Once you do the icon goes away.
Dec 03, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
