Question about Kenmore 659 Electric Dryer
Kenmore mid 1994 110 96281100 no power to element
Kenmore mid 1994 110 96281100 I do not have power to the element. How do I check back to other components? I assume I need one probe on a power source and other at the component in the circuit. Can you explain specifically where and how to do this?
All components closed(ohms). Element checks out in every way. 240 Vac to power cord input.
  • mgrim Nov 12, 2009
    all fuses and thermostats are closed. no power measered at the element. how to check back.
    I don't have power to the element. need to check voltage back through circuit. How?
  • Kenmore Master
  • 7,482 Answers
Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Nov 12, 2009
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
Kenmore 790.46994 Everything including Broiler element works great but lower oven heat element does not get hot?
Does the element pass the short test? Check between the element leads and anywhere on the element except the other lead. If you get a circuit, its shorted. When you say power to element OK, are you getting 220Vac? If yes its OK, if not, its not OK.
Mar 02, 2015 | Kenmore Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Kenmore Elite Dryer won't start. Stopped in mid cycle. Timer replaced, still not starting.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 10, 2011 | Kenmore Dryers
Kenmore heavy duty dryer all of a sudden quit heating up
Is there a breaker reset on the heating element? Could be the element itself went bad, or the controller for it. Does it want to go through a full cycle, just no heat? Remove back panel and check for power at the heating element. If power is present, the heater is bad. If not power, follow the power line back to the controller and check for power there. continue until you have power and replace the failed component.
This is most likely 240 V, at the heating element, so if you are not comfortable doing this, don't! I won't tell you how to check for power with a meter. If you don't know, you should not be back there. sorry to be blunt, but 240 V kills.
Good luck
Spencer
Oct 07, 2010 | Kenmore Dryers
The top element on our Kenmore stove seems to be out
yes, turn of power either unplug or kill breaker,,,, remove screws on inside back wall that anchor the element, pull element out a lil and remove wire connections make sure they dont fall back inside opeening they cam out, you can test the element for continutity with a meter or check for any breaks in the element itself....... if u need to replace the element locate your model number sometimes on frame behind drawer,, call a parts place or go online to sears and use their parts reasearch thing and locate your part number most elements can vary from 30-80 dollars hope this helps
Jan 31, 2010 | Kenmore Kitchen Ranges
Washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
E1 comes on during mid cycle and stops the dryer from drying
replace the compressor "compressor relay and the compressor overload" that are on the side of the compressor.
location: should be in the back on the bottom behind the panel.
if you have a circuit board they may need to be replaced as well.
May 09, 2009 | Kenmore Elite HE4 Electric Dryer
The dryer timer runs but the dryer does not
burned out element probably to much lint on the element and motor unplug dryer and take back off and use a vacume to vacume up all the lint and look at the element to see if they are broken they are fairly cheap .cheaperthan a new dryer also check the belt it mighjt be broken
Mar 23, 2009 | Kenmore 62622 Electric Dryer
Kenmore front load washer HE
could possibly be the heater element failed check it with an ohmmeter should read below 30 ohms if there is no reading then it is open circuit and needs replacing
May 18, 2008 | Kenmore 46462 Front Load Washer
Kenmore 659 Electric Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
