Question about Pinnacle Dazzle DVD Recorder
I'd like to know if it's possible to use DVD files recorded with the DVD recorder into Pinnacle Studio 12.
  • 81 Answers
Yes.
Posted on Nov 13, 2009
Dropping frames during capture with Studio 12 Ultimate for Windows Vista
Hello , rozkr
This means the video quality settings are to high for your machine .
Reduce quality . Issue should be solved but image will be less sharp .
Best results for capturing video movies or tv programs are obtained with a stand alone DVD or Blu Ray recorder .
Regards ,
fanaudi
Mar 13, 2011 | Pinnacle Studio Plus 12 for PC
I have a mac and a dazzle dvd recorder. Are they compatible?
Hi patrick,
Looking up the Dazzle DVD recorder, I found this:
System Requirements
  • Platform: Windows Vista / XP
But, Pinnacle who makes the Dazzle does have this info on Mac Video capture:
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Family/Video+Capture+for+Mac.htm
Hope this helps
Dec 26, 2010 | Pinnacle Dazzle DVD Recorder
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
How can I import my videos from my Hi8 video camera to the Dazzle Plus Pinnacle 12
Welcome to fixyah,
Open your Studio 12 and then click on capture tab and then go ahead and click on setup capture source under video click and choose your dazzle device. Connect your yellow red and white cable to your dazzle and then end part to your HI 8 camcorder. Open your camcorder and when the video showing to your preview windows of Studio 12 then hit start capture
Jul 30, 2010 | Pinnacle Dazzle DVD Recorder
Sound out of sinc with video
Hi and welcome to Fixyah,
Could you please let me know what particular software or program that the video and audio is out of sync. Did you used Pinnacle Studio program or the Pinnacle Instant DVD recorder?.
Mar 13, 2010 | Pinnacle Dazzle DVD Recorder
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
How do I transfer recordings off my lg hdd RH1999H to my laptop? Is it even possible?
The generic answer is yes you can. You will need to use a software app like Pinnacle Studio V10.5 onwards (currently V14) or similar II think that Roxio have a product too) that will take raw video format from the DVD Player / recorder and convert it to MPEG2 files that you can then convert to any other format. You can then edit them and put them back tot he DVD Player / Recorder in the correct format for viewing on TV. This will also allow you to burn customised discs with TV content etc.
Oct 18, 2009 | LG RH1999H DVD Recorder/HDD Recorder
IUSED MY DAZZLE DVD RECORDER MANY TIMES BUT
Please check this link http://pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Plug-Ins/Instant+DVD+Recorder+Support/Download+Area/Drivers+-+Updates/IDVDR261.htm?mode=documents&Display=1 that is for the instant DVD recorder program you can download and install that to your computer. Now if you need Studio program just call Pinnacle customer service and then asked for the replacement disc for $14.95 only.
Oct 01, 2009 | Pinnacle Dazzle DVD Recorder
No colour when I record using the Dazzle DVD Recorder.
Get a program called amcap and you also need pinnacle studio first open pinnacle studio then go to capture then if your using 12 dv then open amcap an error will come up then go to options then video filter settings or something then where it says pal or ntsc change it to secam b then go to pinnacle studio and look at the preview, it is in color then when you start recording it goes black and white again so open amcap go to options then video capture filter then change secam to ntsc then apply then go to secam b again then it will be recording in color then you have to cut out the black and white in pinnacle studio or any other video editing program I use sony vegas pro 9 then search tutorials on the program but it is easy in any program really.
Mar 11, 2009 | Pinnacle Dazzle DVD Recorder
Instant DVD Recorder stops working when I try to capture
Please try to uninstall the program Instant DVD Recorder.
Download the latest version of Instant DVD Recorder in the link below which is the 2.6.
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Plug-Ins/Instant+DVD+Recorder+Support/Download+Area/Drivers+-+Updates/IDVDR261.htm?mode=documents&Display=1
Make sure that the program that you have must be uninstall first before you start downloading the file and install it.
Jul 18, 2008 | Pinnacle Dazzle DVD Recorder
Pinnacle Dazzle DVD Recorder Logo
42 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
