Screen shows "no data found". 2153112 Sep 2, 2015 8:53 AM. Screen shows "no data found". 20 Views; Categories: Senior Care - Assisted Living, Home Health ...
Charter CommunicationsTV with grey screen displaying words - No Data. If you are seeing the words "No Data" on a gray screen on your TV, follow these troubleshooting steps.
If the unit holds no data transferred from SonicStage, the screen shows NO DATA. User can playback the tracks recorded with the unit from HOME screen - Rec ...
There's a display "toggle" sequence on your computer to send the signal to your external post (VGA?). Look at the Function keys (top row) for a screen icon. Hold Fn key down and press that Function key (on Dell, usually F8). You should get an indication on your screen of which outputs are active -- look for BOTH.
How to do constant multiplication or division on the Canon P170-DH calculator
This process actually requires fewer keystrokes than other calculators. Basically, just do the first problem and then do the next items with just the next number and the EQUAL key. For example,
*** Constant Multiplication *** 2 (multiply key) 10 (= key) (The answer 20 shows on the screen. Note, the 2 is still stored as a constant without doing anything, just continue) 4 = (shows the answer 8 on the screen) 20 = (shows the answer 40 on the screen) 100 = (shows the answer 200 on the screen)
*** Constant Division *** 10 (divided by key) 2 = (shows the answer 5 on the screen, the 2 is still stored as a constant without doing anything, just continue) 100 = (shows the answer 50 on the screen) 500 = (shows the answer 250 on the screen) 4 = (shows the answer 2 on the screen)
This process actually requires fewer keystrokes than most other calculators. Basically, just do the first problem and then do the next items with just the next number and the EQUAL key. For example,
-------------- Also note! There is no K visible on the screen to indicate a constant is set.
