Question about Dishwashers
No power when you press the start button/dishwasher latches properly
  • 17,970 Answers
PROBLEM: WON’T START AND START/RESUME KEY LED FLASHES 3 TIMES WHEN START/RESUME KEY IS PRESSED.
Control programmed to not start if it suspects door switch is stuck
closed. Control looks for switch to open between cycles.
■ Customer didn’t open door between cycles.
■ Door switch contacts are stuck closed.
1. Open and close door and then press Start/Resume key. Instruct customer.
2. Unplug dishwasher or disconnect power.
3. Check resistance across door switch in Power Up circuit. Confirm proper latch assembly operation.
Faulty control.
1. Unplug dishwasher or disconnect power.
2. Check/replace control.
PROBLEM: WON’T RUN AND LED FOR START/RESUME KEY IS
BLINKING SLOWLY
By design, if the door is opened or power is interrupted during a cycle,
the user must press the Start/Resume key to resume operation.
Instruct Customer; refer to Use & Care manual.
The door must be latched for the Start/Resume key to work.
NOTE: For models with all keys on top of the door, the Start/Resume key can be pressed with the door open but the door must be latched within 3 seconds.
Confirm door is closed properly before pressing Start/Resume key.
Door switch not making contact:
■ Faulty door latch assembly.
■ Faulty door switch.
2. Measure resistance of door switch contacts while checking mechanical operation of latch assembly. Confirm switches not loose from assembly.
RESUME
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Hope helped with this.
Posted on Nov 12, 2009
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Press START and nothing happens
yes the door has a safety switch that will keep the machine from starting, this is most likely the problem.
Aug 12, 2008 | Kenmore 15762 Dishwasher
Ariston Dish Washer LSE620A
test this steps and fix it. God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Westinghouse Dishwashers
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Our Kitchenaid dishwaser will not start.
If all other buttons are working and you can make program settings, then the door switch is not making proper contact. The door has to be firmly closed so that the switch inside the latch tells the controller that it is safe to start the dishwasher when the Start button is pressed.
Try to turn the mains power to dishwasher off and back on and see if there is any difference.
Oct 18, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Model KUDS01IJBL0 will not start. Keeps reverting back to 2 minute drain when Cancel button is pressed. After the 2 minute drain, I press "Normal" button, or any of the other start buttons with...
If your dishwasher won't start the problem could be the door latch or door latch switches. The door latch assembly is used to hold the door closed during the cycle to prevent water from leaking and it also incorporates the door latch switches that supply power to the dishwasher controls. If the door cannot close properly to activate the door latch switches or if the switches are defective then the dishwasher controls will not receive power and the dishwasher will not start. Inspect the latch assembly including the switches.
The door latch assembly is typically located at the top of the door, behind the inner door panel. To gain access you will have to remove the screws that secure the inner door panel and then separate the inner and outer door. The door latch assembly will normally have two switches that are wired in series as a safety feature. Verify that the door catch will activate the switches by manually inserting the catch into the latch assembly. If both switches are being mechanically activated then you should next check the switches for continuity with a multi-meter. Remove power from the appliance before attempting this repair.
You can learn more on our recent post about the dishwasher 5 simple mistakes you make while using dishwasher Kitchenutilitypro
Sep 26, 2017 | KitchenAid Dishwashers
My Whirlpool GU2455 dishwasher door stopping latching all of a sudden. I press the Start button. It just blinks and nothing starts up. Seems like the door latch lost its grip and hangs loose when you touch...
the door latch actually has usually 2 microswitches on it that connect to the timing device ie: timer or control board:: if the door is not latching properly then it will not power the control board and the blinking light is a failt code telling you that... it sounds like the door latch is broke and needs replaced... i would order a new latch very easy to replace. you remove the inner door panel of the dishwasher and then will see the door latch mechanism made of plastic of course isint everything these days.... replace it and reconnect the wires ...obviously i would suggest turning your breaker off to dishwasher prior to operating on it....a few good reputable sites to order parts from
www.sears.com
www.repairclinic.com
www.apdepot.com good luck to you
Feb 11, 2011 | Whirlpool GU2455XTS Built-in Dishwasher
Dishwasher has power but will not start when start button is pushed
hi there,
if your dishwasher is recieving power and the circuit is controled by a switch,the swtich is faulty,check the swtich by multi tester if switch is defective replace the switch with new one.
check also the door if is tightly closed and latched.The diswasher will not operate until the latcht is prop[erly engagaed.to check this close and latch,closed and latch the door,holding the latch tightly inb place,then still pressing the latch closed, turn the control knob to the ON position.check if the dishwasher work,the latch is faulty and should be cleaned and tightened or replaced.best regard
Aug 09, 2009 | Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
