Question about Acer Aspire 5050-3242 Notebook
Toshiba A105 laptop
Hi , my sons laptop suddenly stopped working right since he added a new stick of ram. The wireless internet no longer responds , the light doesnt turn on and also his touchpad stopped working
    Novelist:
  • 101 Answers
Hi Harry! Did you remove the ram? Sounds like it is either not compatible. Good luck!
Posted on Jan 08, 2008
Hi .. i am having a wierd problem with my laptop keyboard. some of the keys just dont want to work. all of a sudden they stop working and suddenly they start working again. can anyone tell me what can be...
have you ever had the keyboard out for any reason...or maybe had ram installed...sounds like the connector that the keyboard connects to may be intermittant...some of these ribbon cables are prone to bad connections...just a thought
Mar 26, 2011 | Toshiba Satellite A105 Notebook
Is windows 7 compatable on a toshiba laptop a105-s171
From what I understand, windows 7 requires atleast 1 gb of ram to run properly, judging by your standard system specs you have 512 mb of ram. Unless you have added some ram or plan to add some to your system then no I dont believe you will be able to upgrade and run windows 7 efficiently.
Feb 09, 2011 | Toshiba Satellite A105-S171 (PSAA2U005019)...
MY Toshiba Satellite A105-S4004 no longer recognizes any RAM module (original one or new one works in other RAM slot without problems). If I insert a matching RAM module in this slot the notebook will no...
try look the ram module pins support, if any pin broken, or defective, to correct this you need a small tool to put it back on place. (only with power off and battery off). if some pins has not the right place, the computer dont boot.
Dec 29, 2009 | Toshiba Satellite A105-S4004 Notebook
I have toshiba satellite a105 i wanted to know if it have wireless internert or do i need a verizon wireless chip
The Toshiba A105 comes with a wireless card. On the bottom of the laptop there is a door toward the front middle and behind that door you can see a wireless card that has the black and white wires going to it.
There is also a on/off switch that enables the wireless card as well, its either on the left or right hand side of the laptop.
Just make sure the switch is turned on and go into the device manager and underneath where it says network adapters, you should see the wireless card listed in there.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
My Toshiba Satellite A105 keeps hanging up. It
No matter what, backup your data now.
Then try running a hard disk scan to check for bad sectors. Some software apps will actually block off the bad sectors and prevent your system from trying to use them again.
However, I suspect that the issue is actually a memory or video card problem. Try installing memtest86 (http://www.memtest86.com/download.html) and running on your system.
-Jon
Sep 29, 2009 | Toshiba Satellite A100-S8111TD Notebook
I have a toshiba satellite a105-s2716 I was
Some laptops have a button to "disable" the wireless adapter.
Click START
Click Control Panel
Click Classic View
Click Network Connections
Check that the wireless adapter is "enabled".
Right-mouse-button click on the icon for the wireless adapter,
and then click "repair".
Sep 14, 2009 | Toshiba Satellite A105 Notebook
Won't power on
Hi gdpreston1,
According to Toshiba all you need is a bios upgrade.
In very rare cases, the battery pack of your PC may stop accepting a charge, i.e., the battery stops working & no longer supplies power to the computer. To minimize the risk of ever experiencing this problem. Toshiba strongly recommends that you download and install the latest BIOS by clicking this link below.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=1795538&moid=1310944&rpn=PSAA8U&BV_SessionID=@@@@0783506992.1202186758@@@@&BV_EngineID=cccfadedefffiikcgfkceghdgngdgmn.0&ct=DL&all_docs=true
ACPI Flash BIOS version 5.90 for Tecra A7/Satellite A105 (Intel) (PTA70U).
File: ta7i0v59.exe
From what you posted you "are" experiencing the above.
Much better than buying a part!
If you need anything else just post back & we'll go from there.
please vote...
map
Feb 05, 2008 | Toshiba Satellite A105 Notebook
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Acer Aspire 5050-3242 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
