Question about Sony VAIO Notebook PC VGN-NS235J/W
Two buttons beneath touchpad are not working
There is the touchpad with right-click and left-click buttons beneath it. The right click button seems to be working fine but the left click button is not working at all. PLEASE help.
You should clean the button by opening the cover, realign it, and check if the button touches to the board.
Posted on Nov 27, 2011
Left click will not work
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar . Or disconnect the mouse from your computer restart.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Hope this helps.
Jan 23, 2013 | Toshiba Satellite C655-S5123
Touchpad not working right
You need to re-open your laptop cover to check whether the wire contacts of the touchpad connected to the motherboard of your laptop are all OK.
Also, this kind of issues occur if something like water or oil is on the touchpad causing it to not behave as expected (eg: scrolling one pos at a time instead of all the way down ). Also if your fingers are sweaty this can occur.
Now, for the right-left clickable buttons of the touchpad, you probably need to check again if anything's broken on the inside of the laptop.
Jan 29, 2012 | Acer Aspire 9300-5349 Notebook
Left button of the Asus Eee 900 is not working?
I guess you mean the left touchpad button. With my 900 that happened after only 4months extensive use. Reasons could be dirt in the microswitch under the button or broken contact of switch on MB. To exclude software problem, switch buttons in touchpad driver panel and see if the right button function is not working when pushing the left button. If you don't want to open your eeepc to clean or fix, activate the tapping option in the touchpad options and asign a "2taps with one finger" to a left mouse click for replacement. I work with that for almost 2 yrs now without ever using the left button again. Should you just switch buttons, be prepared that the right button might leave you too in a while.
Take care,
Juan
Jan 17, 2011 | ASUS Eee PC 900 PC Notebook
Touchpad has stopped working, can you help?
Hi there don't worry. Its disable that's why not working. Please press FN+F7 and try. The symbol on your keyboard is below. Just press FN+ below mention symbol. Thanks.
Apr 07, 2010 | Acer Computers & Internet
I have Dell laptop and the buttons on the touchpad sopped working
I would just install a usb mouse through one of you usb ports
Option 2 is to spend a lot of money to have both switches cleand/repaired
Nov 21, 2009 | Dell F3534 Touchpad
Disable Touchpad Clicking
Hiya, At the bottom right of the screen, by the clock, you should see an icon for the touchpad.....
Hint : Hover the mouse over the icons and wait for the "Pop-Up" Display to see what they do if your not sure.
When you find the one for the touchpad, simply right click it and scroll down to the option that says "Tap To Click" and left click it so that there is NO TICK next to it..........
........ This will DISABLE all tap click options and leave the touchpad as a touchpad and the buttons as buttons...........
Hope This Helps, Kind Regards,
Me :D
Mar 19, 2009 | Compaq Presario 700 470024-192 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Acer aspire 3692WLMI - problem with arrow
Go to acer website and download that model manual, make sure you have ADOBE READER on this machine..If your pointer is not working then you need to download the touchpad driver or if you are using a mouse then it may be a bad one.
Aug 24, 2008 | Acer Aspire 3690-2196 Notebook
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Left side of touchpad not working
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Pointer/Navigator"). If there is some kind of a "Warning" icon superimposed on the "Pointer/Navigator" icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.").
Or it could be dirt or soda.
Oct 29, 2007 | Compaq Presario V4000 Notebook
Sony VAIO Notebook PC VGN-NS235J/W Logo
690 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
