Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark x4720 ink cartridge installation
I just installed a new black cartridge. It snapped in fine, and, yes, I took the tape off. Now printer is giving me a message saying Black Cartridge is Missing. Any ideas? I have turned the printer off and on, still nothing. I have taken it out and reinstalled many times as well.
  • 1 more comment
  • Anonymous Apr 23, 2009
    same thing
  • Anonymous Mar 20, 2014
    lexmark Z735 printer... I have never had any problems changing an ink cartridge
    lexmark Z735 never had this problem before.... did an "expection" with my flashlight... nothing seems broken or stuck in the space
Stop buying lexMark products, They are not worth the plastic they are made from.
Posted on Jan 13, 2008
Unplug that S.O.B. it worked when it kept telling me repeatably to reinsert the ink cartridge even though I did several times.
Posted on Apr 24, 2012
    Problem Solver:
  • 15 Answers
Clean contacts on printer and cartridge sometimes tape leaves a little sticky stuff behind,also look for reset button on cartridge.
Posted on Aug 22, 2010
Newly installed n0016 black ink cartridge shows full level after installation but is not printing black in any test sheets on lexmarkx75
duhhh on my part. i had removed the triple colored plastic coating i normally do and proceeded with the addition of the new print cartridge. it didn't print black and i checked and rechecked and reinserted. then i wrote to you guys. i took both cartridges out and caught a glint on the bottom of the black ink. blind bat here.. there was a section of tape that i failed to see (with my glasses on yet). so that was the solution. tape removal. my prior cartridges each had the one tri colored strip. i failed to feel or see the additional section of tape. thank you fix ya- i really would have felt stupid having you guys spend time assisting me.
Nov 05, 2009 | Lexmark X75 All-In-One InkJet Printer
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Put new ink cartridge and can't install
Replacing your cartridge:
  1. Make sure the printer is switched on.
  2. Pull the operator panel forward and open the cartridge access door. (Note: The cartridge carrier moves to the loading position, unless the printer is busy).
  3. Pull the old cartridge forward and then lift it out.
  4. If the cartridge is new, remove only the sticker or transparent tape on the bottom of the Cartridge.
  5. Insert the cartridges into the carrier and push back firmly until they snap securely into place.
  6. Close the cartridge access door and the operator panel.
  7. From the operator panel, press Options to select the cartridges that were changed.
  8. Press Start (Start/Yes), Options to select the cartridge type installed.
  9. Press Start (Start/Yes).
Sep 16, 2008 | Office Equipment & Supplies
Lexmark X1270
Does the printer attempt to print? Did you replace the black or colored ink? If it was the black ink will it print in color?
If it prints in color, check the black ink cartridge for tape residue on the gold contacts. The blue tape will sometimes leave the adhesive on the cartridge and not the tape. It cleans off easy with a soft cloth.
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
I installed a new "genuine" Lexmark color ink cartridge, but it doesn't work.
then get it replaced by lexmark as the cartridges comes with one year warranty..
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 1200 does not recognize black ink
that's good..after replacing a cartridge, it's highly recommend to do a clean and re calibrate...you can do this from front panel.
Mar 09, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark printer
Lexmark technical support should be able to help resolve this problem, assuming the cartridges were Lexmark branded. Contact information is on www.lexmark.com.
Feb 13, 2008 | Lexmark International Z611 Printer
Lexmark X4270 All-In-One InkJet Printer Logo
597 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
