Question about LG Refrigerators
WHAT IS THE ICE GUIDE?is it the thing that you put under the dispenser so the ice won't fly away?
    President:
  • 1,653 Answers
That is correct.
Posted on Nov 12, 2009
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
How do I remove ice dispenser from samsung rfg297aars
here ya go.
https://www.ifixit.com/Guide/Samsung+French+Door+FRG297HDRS-XAA+Ice-Water+Dispenser+Microswitch+Replacement/66568
Grab the black dispenser port with a strong hand and hold the door from opening with another, or your shoulder. Firmly pull the assembly away from the door. It will take a quick, firm pull to do the deed. The assembly is held in place by several plastic lock tabs. These will give way without breaking.
pushing the fridge back will be easier than pulling it around.
Best of luck and hope this helps you.
Jan 18, 2018 | Samsung Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
When we get ice it flies all over the floor and makes a mess, is there a fix or do i need to return it
Hi.
The ice dispenser is defective. First check if there is ice blocking dispenser door or mechanism. That may prevent the ice-maker from stopping or may cause the ice dropping on the floor. In case try removing food and defrosting the unit completely (leave it off for 24 hours), or use an hairdryer on Cold settings to defrost manually ice from dispenser and icemaker.
If that does not work, then the appliance must be repaired. That does not mean that the fridge will be returned. The manufacturer will send you a technician to replace ice dispenser at home. If the unit is less than two years old the repair will be carried free of charge under warranty conditions.
Here all the parts and diagrams for this unit: RS2630SH/XAA.
Regards.
Ginko
Aug 08, 2011 | Samsung RS2630SH Side by Side Refrigerator
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
We have a GE GSH25JSTSS Whenever we use the in door ice dispenser it dispenses the cubes, but also sprays ice chips in all directions and we have to wipe up the floor every time we use it. Is there a...
you have ice buildup in the ice crusher, take the ice bin out and let it thaw in the sink over night, make sure to dry the wholr thing well before putting it back in
Nov 11, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice maker in freezer fills up but won't dispense ice cubes. Also, there seems to be a large build up of ice under the dispenser
some ice makers have heating elements in the trays to melt the ice away. that way it will despence.element could be bad.
Jul 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
