Question about Pantech C470 Matrix Smartphone
I have a Pantech Matrix and want to hook it up to my computer, where can I get the software to install into my computer so I can transfer files/ recordings?
Pantech ease 2020 photo transfer
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain something that looks like PTQH_V1_1_4583_1215_SETUP - Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Apr 23, 2012 | Pantech breEZeTM Cellular Phone
Purchased a USB cord to download photos from my phone. Can I use it without having a disk to install it into my computer?
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Dec 08, 2011 | Pantech Cell Phones
Pantech pc controle suit
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to "Program Files" on your computer. You need this software before you will be able to connect with your phone. If this download does not work on your computer it could be that it is not able to get past your security or firewall settings. If you still can not get it to download I would go to another computer and transfer the program for that computer to yours with a USB flash drive. (2nd) after you download this software you need to go to and open the "Program Files" folder on your computer. Then open the "Pantech" folder. Next open the "Pantech PC Suite" folder. Now open the "P2020" folder. Finally open the "USBDriver" folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this is a helpful solution for you.
Nov 22, 2011 | Pantech Ease P2020 AT&T
I have a pantech p2020 ease and i cant get my computer to recognize it..
Mar 12, 2011 | Computers & Internet
My pantech ease won't send pictures.
Jan 10, 2011 | Cell Phones
When I plug the Pantech Matrix C740 into my laptop with a USB cord, the computer can not locate a driver anywhere for the phone. I want to be able to transfer pictures from the phone to my computer and...
Hi, you have to install the driver for the Pantech Matrix before you can perform such functions like transfer of picture and music. Most phones come with their drivers in a CD, just like the Nokia Pc Suite and Motorola PC suites i use...
Without that you can hardly perform such functions, but you can try again by connecting you phone to the laptop through the usb. Go to my computer on your PC and you will see the memory card of the phone appearing under the section "Devices with removable storage"..
Click to access it and add or delete whatever you want and it will take effect on the memory card of the phone only....
Take care
Mar 08, 2010 | Pantech Matrix Cell Phone
Transfer pictures from my pantech matrix c740 cell phone to my pc
if you have a oicture you wanna save to your computer all you have to do is:
1. find the piicture you want to send
2. click options then send
3. pick "to HP's Snapfish
4. wait for a couple of minutes it will send you a code and go to it
5. you have to make an account after that you click on your picture album
6. right click your picture then click "save as"
7. save your photo with a name
8. by then you have your photos saved on your computer
Mar 30, 2009 | Pantech Matrix Cell Phone
Pantech Matrix Software
Well the pantech matrix is still considerd a NEW phone. So many people are working on making new software for the pantech matrix. It should be coming out soon. That is why they have just found out like a month or so ago how to unlock the phone. Sorry for my spelling and puncuation errors i was in a rush.
Feb 12, 2009 | Pantech Matrix Cell Phone
Pantech c300 data cable use
Apr 03, 2008 | Pantech C300 Cellular Phone
Pantech C470 Matrix Smartphone Logo
37 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
