Hi, where can i get an alternative power supply other than usb to charge it? regards pete
    Sergeant:
    Champion:
  • 225 Answers
You can use any usb adapter with a jack suiting your device (commonly mini USB) and equal or higher power than the one mentioned on the device. Voltage for usb is 5.0 volts, still check what the device says. I have never seen a usb adapter on different voltage tho.
I had to buy a spare adapter for my Qtek 9000, chose Spyke, model PST-2005U. It gives a whole 2.0A, can charge up to four standard devices (0.5A each as per usb port standard). It has also easy to notice LED, data input, so that you can access the device even when charging, and a replaceable cable on a USB plug, so that you need just one cable to charge your device and connect it to PC.
Here it is: http://www.maxtronix.biz/product/2008-4-26/2008426122753.html
It has several options, so be careful.
Posted on Nov 12, 2009
My 18v worx drill batterywont hold a charge
sounds like the battery is kaput you can only charge a certain number of times or the battery has developed a memory which causes it to fail, usually caused by not fully discharging it in use and putting it back on charge when the battery still has plenty of power left. the cycle is fully discharge then recharge or check your user manual on battery
regards pete
Jul 02, 2014 | Drills
Need power supply for kensington PocketHUB 7 Port USB
The K33366 POCKETHUB 7 PORT HI-SPEED USB HUB requires a 5volt supply at 4amps
regards
Jul 02, 2014 | Kensington K33366 POCKETHUB 7 PORT...
Can i charge an Olympus fe-4000 with a usb cable connected to my computer?
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Jun 28, 2010 | Olympus Cameras
Can you hook your amp straight to your alternator with no problems
Hi TW,
Please ignore the post here by 79 as anything but fiction.
An alternator produces DC current not AC. It does however fluctuate quite a bit. It's the low voltages that will stop your amp from functioning.
Whether you connect your amp to your alternator or your battery doesn't matter. They are connected to each other already. The battery stabilizes the current to your amp. When the amp requires more than the alt can supply, the battery fills in.
Personally, the battery is easier to connect to.
Best regards
Mike
Feb 21, 2010 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
When i connect to usb port it says insufficent power supply. What should i do
You will need to buy get a POWERED HUB,as the USB port can only supply 500mA and your device needs more.
Feb 21, 2010 | Transcend T-Sonic 840 MP3 Player
Bmw 2003 325ci coupe... i have just replaced the battery and the battery light is still on is this another fault or a faulty battery. Also every now and then the Yellow warning light on the dash for the...
Hi Stuart, the battery light indicates that the alternator is not charging. The alternator needs to be repaired or replaced in the case where the alternator is the problem. Before replacing the alternator you might want to check your fuses. It might be that one of the main fuses blew, causing the alternator not to charge. The traction control light will come on if it detects a problem with the supply voltage to the control unit caused by the alternator not charging.
Nov 24, 2009 | 2003 BMW 325
Ultra 350 Power supply very loud fan
It's not normal for the fan to be loud, what makes them loud is either a build up of dust on the fan blades or the bearings are going on the fan itself.
If the PSU is working fine then you can replace the fan itself from an identical PSU. It does mean taking the PSU out of the computer and fitting the fan yourself.
Alternatively you can purchase another PSU.
Regards.
Aug 30, 2009 | Ultra (9PA3501609) 350-Watt Power Supply
With a BT Freelance telephone recently purchased, the instructions don't explain how to erase a phonebook entry. The user guide supplied is not very clear and I am unable to access the download mentioned...
Why I didn't think of it in the first place - I got my son to fix it for me, how, I really don't know. Thankyou very much for your interest.
Regards, Pete (Chugger)
Sep 18, 2008 | Lands Phones
How do I charge my MP3 ?
Hello camerorunner,
Most MP3 players can be charged by connecting them to a computer's USB port using the supplied cord. Make sure you are plugging the MP3 player into a USB 2.0 port directly on the computer itself, not on a USB hub. Most USB hubs do not have enough power output to actually charge your player.
The player may also be supplied either a wall adapter or car cord that can be used to charge the unit. However, most manufacturers sell these items as optional accessories.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 17, 2008 | Audio Players & Recorders
Regarding battery problem/battery not charging
Hi Jasbir, Laptop batteries only have a set life span and if your battery does not hold charge the only solution is topurchase another battery. You will find the cheapest way to do this is to search the computer section of ebay [laptop assessories ]
and find the battery for your laptop model.
Regards mistyman
Nov 16, 2007 | Computers & Internet
150 people viewed this question
 Grubhead
Grubhead
