Question about Epson Perfection 2400 Photo Flatbed Scanner
HOW DO I GET MY SCANNER TO SCAN TO MY PC - Epson Perfection 2400 Photo Flatbed Scanner
I have the pro 95 scanner and all my frequences have been erased. a friend of mine had mentioned that i could get my scanner frequences off line by pluggind into a usb from scanner to computer . but what site do i go to and is it free
Posted on Nov 13, 2009
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
Need to scan docs from scanner to pc
You have to install scanner and printer software came along with the HP 3030 model.Once setup complete it will try to do self diagnose the scanner connectivity.Then when you press the button on the scanner ,scanner will send the data to pc to activate the scanner software automatically.
Nov 26, 2012 | HP LaserJet 3030 All-In-One Printer
I would like to scan a document. I am using the All In One printer. I am using a brother printer with the printer, fax, copier, scanner, and PC fax. How to I begin to scan my document?
Hi Gerrid,
There should be a scan program on the pc or a scan button on the scanner itself. You can go to the brother website and see if you can find a downloadable program for this unit. Alternatively, if the scanner is 'seen' by the pc, you can search your Windows program for "Windows Fax and Scan" from which you can select "Scan", if the printer is seen it will do the job, if not, it will tell you "No Scanner found".
If the scanner is not found, you can go to "Device Manager" and do a scan of the pc to detect "Plug and Play" devices. This should find the scanner.
I hope this answers your query, Please rate and comment, Thank You Joe
Sep 07, 2011 | Computers & Internet
Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
Feb 01, 2010 | Canon PIXMA MX850 Multifunction Printer
CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
I AM ATTEMPTING TO USE THE SCANNER FUNCTION ON A CANON IR2230
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
Jan 01, 2010 | Canon IMAGERUNNER 2230 Copier
How do i use the scanner on my Canon MX310 ?
You need to control the scanner thru your PC with canon software that came with your printer/scanner otherwise you cant scan anything..
First open the printer/scanner software on PC,select scanner,then place your document and command "scan" on your PC..On this window you can also alter the scanner preferences..thats it..
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
I can't get my scanner to work it says try starting scan from put
First you have to load the scanner (twain driver). Then load the scanning software. Then plug the printer/scanner into the usb port on the pc. The pc should then recognize the scanner. You might have to turn your pc off then on again to recognize the scanner. Then try to open the scanning software on your pc and put the document on the scanning glass and press the aquire/scan button on the software. Hopefully, that should work.
Sep 14, 2009 | HP PSC 2410 All-In-One InkJet Printer
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Cannot scan to pc
my MP 160 cannot scan to pc, but can print and photocopy well. it says it cannot communicate with scanner..cable might be disconnected or scanner might be off..tried uninstalling and reinstalling..still doesn't work
May 21, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Epson Perfection 2400 Photo Flatbed Scanner Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
