Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
A stream of water leaks out of the bottom of the fridge at night.
  • 2,237 Answers
The condensate pan under your fridge has overflowed. this pan catches any condensation from the evaporator coils.
Posted on Nov 12, 2009
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
Fridge working perfectly... water leaks onto floor over night seems to be from underneath..
I would check that the water catch tray is on the compressor, this item collects the water from a defrost, it may be missing.
Dec 04, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is streaming out the bottom of my fridge on freezer side
the water should evaporate when hitting the coils,maybe coils s/b cleaned (dusty)
Mar 17, 2010 | Refrigerators
I think my Whirlpool French door (freezer on bottom) is leaking underneath. I have checked the water lines on the outside and looked underneath and nothing. When I moved the fridge there was a film of...
check to make sure that the condensation pan is in its correct position,, somtimes when the unit is moved up steps it causes the pan to sit in there cocked or unlevel and will drain out excessively. or it may be a crack on the fill valve solinod where the water line connects to the fridge.. there will be a blue plasitc cover right where the water line connects to the frig and somtimes they crack and will only leak when the ice maker calls for water... pull out the frig and empty the ice tray and when you here it start to fill up the icemaker check around that solinoed be sure to use a bright flash light because sometimes the leak will be a little stream of water that is really hard to see sometimes you can only feel it with your fingers...I hope this helps......
Nov 11, 2009 | Whirlpool GX5FHDXT French Door...
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
Nov 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
179 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
