I just delete by accident an application call PMRES08.dat from my program soft maker office 2008 and now the program do not open. How can I fix this.
    Problem Solver:
  • 18 Answers
Just reinstall the soft maker office 2008
Posted on Nov 13, 2009
(Error code: 0xE000003D) IN ONE NOTE
hey, you may follow the below steps:
Steps to Fix/Resolve/troubleshoot the error code 0xE000003D:
1 - Repair your Office app
Error Code 0xE000003D will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error.
  1. Open Control Panel using Start.
  2. Click on Programs and select Programs and Features.
  3. Click on the Office product that you want to repair.
  4. Click Change.
  5. Select Quick Repair and click on Repair. If Quick Repair didn't fix the Error Code 0xE000003D, select Online Repair and click on Repair.
Note: If Office Repair did not fix this error code, then remove and reinstall the Office installation to fix this Error Code 0xE000003D.
2 - Steps to remove Office
In case if the error persists even after running Office repair tool, uninstall Office from your computer.
  1. Click on Programs and select Programs and Features.
  2. Select Office Suite and click on Remove.
Note: If Office installation failed or it didn't fix the error, a manual installation is required to completely remove the Office Suite.
3 - Steps to remove Office manually to fix the Error Code 0xE000003D
If the error code 0xE000003D is re-occurring, proceed with the following steps to manually remove Office program from your computer.
Step 1: Remove the Windows Installer packages
  1. Find the Office 16 installation folder, typically located in C:\Program Files\.
  2. Right-click the Microsoft Office 16 folder and select Delete.
Step 2: Remove the Office scheduled tasks
  1. Open a Command Prompt window as an administrator.
  2. At the command prompt, type the following commands and press Enter after each one:
schtasks.exe /delete /tn "\Microsoft\Office\Office Automatic Updates"
schtasks.exe /delete /tn "\Microsoft\Office\Office Subscription Maintenance"
schtasks.exe /delete /tn "\Microsoft\Office\Office Click To Run Service Monitor"
Step 3: Use Task Manager to end the Click-to-Run tasks
  1. Open Task Manager.
  2. Click the Process tab
  3. If the following processes are running, right-click each one, and then click End task after you select each process.
  • .exe
  • setup*.exe
Step 4: Delete the Office files
  1. Press Windows logo key + R to open the Run dialog box.
  2. In the Open box, type %ProgramFiles%, and then click OK.
  3. Delete the "Microsoft Office 16" folder.
  4. Delete the "Microsoft Office" folder.
  5. Open the Run dialog box, type %ProgramFiles(x86)%, and then click OK.
  6. Delete the "Microsoft Office" folder.
Step 5: Delete the Office registry sub keys
  1. Open Registry Editor.
  2. Delete the following registry sub keys:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\ClickToRun
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\AppVISV
  • HKEY_CURRENT_USER\Software\Microsoft\Office
  • Then Delete the Office key.
Step 6: Delete the Start menu shortcuts
  2. Type %ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs, and then press Enter.
  3. Delete the "Microsoft Office 2016 Tools" folder.
4 - Download and install Office
1. Sign in to your My Account page using the link https://go.microsoft.com/fwlink/p/?LinkId=613327
2. Choose Install.
3. Click Run or the equivalent depending on the browser you're using.
4. When you see "You're good to go", click All done.
Error Code 0xE000003D for Microsoft Office Outlook and Windows Updates
Dec 26, 2012 | Computers & Internet
I deleted my Microsoft Office Activation Wizard
try this :
1. Quit all running programs.
2. Download and install the Windows Installer Cleanup Utility.
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
3. After you have installed the Windows Installer CleanUp Utility, click
Start>All Programs>Windows Install Clean Up.
4. Highlight Microsoft Office 2007 entry in the list and then click
Remove. Click OK and wait for the process to end. If any other stand alone
Office applications (such as Visio and Project) appear on the list, please
also remove them. Then, click Exit to close the Windows Installer Cleanup
utility.
5. Click Start>Run, type "regedit" (without the quotation marks) in the
Open box and press Enter.
6. Locate the registry keys below and click Delete from the Edit menu.
Click OK on the following warning dialog box.
Note: Please go to File>Export and backup all the registry first.
HKEY_LOCAL_MACHINE\Software\Microsoft\Office
Quit Registry Editor.
7. Delete or rename the following folders or files if they exist:
C:\Program Files\Microsoft Office
C:\Program Files\Common Files\Microsoft Shared\OFFICE12
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Excel
Data\Microsoft\Office
Data\Microsoft\Outlook
Data\Microsoft\Publisher
Data\Microsoft\Templates\Normal.dot
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Word
C:\Documents and Settings\All Users\Application Data\Microsoft\Office
C:\Program Files\OfficeUpdate12
8. Click Start>Run, type "%Temp%" (without the quotation marks) in the
Open box and press Enter. Delete all the files and folders within it. If
there are some files which cannot be deleted, just leave them alone and
this will not affect the result.
9. Empty the Recycle Bin.
10. To remove Mapi, search for and rename the following folders/files if
they exist:
C:\Windows\system32\mapi32.dll
C:\Windows\system32\mapisvc.inf
C:\Program Files\Common Files\System\Msmapi
C:\Program Files\Common Files\System\Mapi
11. Restart your computer and install Office 2007 again.
May 12, 2011 | Computers & Internet
I tried moving my word application to my desktop and now when I go to open it a error comes up that says that there was a problem opening word and it tells me to reinstall the program. I put in my office...
That's actually a normal problem. You don't need to reinstall Office Mac 2008. What you need to do is to put the the Microsoft Word icon from your Desktop back to Applications Folder. To create a shortcut on your Desktop, go to Applications folder, Right Click(Ctrl+Click) on Microsoft Word then choose Make Alias. Just drag the Microsoft Word Alias to your Desktop. From Desktop you will have Word as a shorcut icon without any problem. If the issue will not be resolved then you need to uninstall then reinstall Office. Here's the steps:
] > Macintosh HD\Applications
* Remove Microsoft Office 2008
] > Macintosh HD\Users\<username>\Library\Application Support\Microsoft
* remove folder called Microsoft
] > Macintosh HD\Users\<username>\Library\Caches
* remove all Microsoft related files
* remove Microsoft Folder
] > Macintosh HD\Users\<username>\Library\Preferences
* remove all the (com.microsoft.[....].plist files)
* remove Microsoft folder
] > Macintosh HD\Library\Receipts\Remove all Office 2008.pkg files
] > Delete Microsoft Office shortcuts from Dock
] > Restart
] > Install Office 2008
> Manual Install Updates
I hope this Helps! :)
Nov 25, 2010 | Microsoft Office 2008 for Mac: Mac
I acidently deleted the port magic in my emachine, and was unable to recover it from my recycle bin. what will i have to do to fix my computer or can I ?
I'm a little perplexed as to how you managed to delete an entire application by accident unless you were in the program files directory within windows explorer and deleted the folder. Are you sure you haven't just deleted the shortcut to the main application executable file? Anyway, you can download port magic free of charge, just search Google and make sure you download the right program as it appears to be a popular name for computer applications. All the best.
Oct 27, 2010 | Computers & Internet
When I start any 2008 office programs they crash right away bad_exc_error I removed and installed a new program and it still does the same thing. Been doing it for about six months, I just bought the new...
If you have the installation disc,
Try this following steps:
Go to the following locations:
] > Machintosh HD\Applications
] > Finder\Macintosh HD\Library\Caches
* remove all cache files
] > Finder\Macintosh HD\Users\\Library\Caches
] > Macintosh HD\Users\\Library\Application Support\Microsoft
] > Macintosh HD\Users\\Library\Caches
] > Macintosh HD\Users\\Library\Preferences
] > Restart , empty your trash bin
Sep 12, 2010 | Microsoft Office 2008 for Mac: Mac
I need to remove the genuine microsoft sottware my system....
Most suites or programs of Microsoft Office 2007 allows user to evaluate the product. The trial version of 2007 Microsoft Office system can be installed by using a 25-character trial product key available from Microsoft while you download the free Office software, and you can use the Microsoft Office 2007 suite or program with full functionality for 60 days.
You may have the Office 2007 CD and are able to install Office 2007 without entering product key. However, Office 2007 will work in reduced functionality mode, where it’s effectively just a viewer for Office documents. Beside, if you forget the trial product key, or don’t wish to register a Windows Live ID to get the trial key, here’s the trick to activate Office 2007, or more correctly, bypass the activation of Office 2007 60 days trial, and making the “trial” word disappear from the Office title at the top and suppress activation and trial expiry prompt.
Note that to use Microsoft Office 2007 beyond 60 days trial period, you need to purchase a valid license for it, available from Amazonir?t=techgadgetrev-20&l=ur2&o=1 or most computer retail store.
To use this hack to crack activation on Office 2007, you need to install Office 2007 without any serial number or product key. If you have installed Office 2007 with a product key or serial number, do the following to clean remove Office 2007 of product key:
  1. Close all Microsoft Office applications.
  2. Run Register Editor by clicking on Start -> Run, and then type “regedit” in the Open box and press Enter key.
  3. Navigate to the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
    Note that inside the registry key, there should be another subkey that resembles the following:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-0000-0000-0000000FF1CE
    or
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE
  4. If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key. For example:
    Product Name=Microsoft Office Professional Plus 2007
    Product Name=Microsoft Office Enterprise 2007
  5. Once found the correct registry subkey, delete the following values: DigitalProductID
    ProductID
  6. Close Registry Editor.
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
  1. In Windows Explorer, brose to the following folder: C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
  2. Right click on Proof.XML file, select “Open With…” in the right click menu.
  3. In the “Open With” window, select Notepad to be used to open the XML file. In Vista, if you can’t see the Notepad option, simply double click the “Other Programs” to unhide it.
  4. Scroll down to the bottom of the Proof.XML to locate the following lines: </Feature> <Feature Id=”SetupXmlFiles” Cost=”1248′>
    <OptionRef Id=”AlwaysInstalled”/>
    </Feature>
  5. Change the AlwaysInsalled to neverInstalled so that the line looks like following: <OptionRef Id=”neverInstalled”/>
  6. Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
  7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
As usual, as it’s a hack, and before you purchase a valid product key for it, you won’t be able to AND can’t access any updates or Microsoft Office Online.
Note: The hack may work for 60 days only. To make this hack fully working, try to delete additional file below, probably has to be deleted every two months:
C:\Documents and Settings\All Users\Application Data\Microsoft\OFFICE\DATA\opa12.dat
Or,
C:\ProgramData\Microsoft\OFFICE\DATA (for Windows 7 and Vista)
Disclaimer: This article is for educational and informational purpose only.
Aug 02, 2010 | Microsoft Office Professional 2007 Full...
Changing Computers for Office 2007
Close office application on tne computer where you have installed office
Go to this following location
Windows vista : C: \program data\microsoft\office\data
Delte all opa12.dat files from the data folder
Open Office application > While opening office applicaiton it will prompt for activation > Select the option which says activate office over the telephone > Call the telephone number respective to your country > Read the installation ID to Activation team they will give another set of numbers typ it in emty box > Click on close .
You are good to go with office 2007
Apr 13, 2009 | Microsoft Office Professional 2007 Full...
Ms office 2003
Generally  this error occurs because you have deleted your word.exe & excel.exe files to confirm of deletion of these application file you can check by following pathway.  If they are not there means you should restore deleted file from Recycle Bin.
      "C:\Program Files\Microsoft Office\OFFICE11
If the file are not available in Recycle Bin then you should reinstall M.S. Office Application.
Or
You can restore your system to an earlier date when it was working prpoperly.
Jan 13, 2009 | Microsoft Office Professional 2007 Full...
What file extension is associated with Microsoft Outlooks offline file?
  • Outlook data files (.pst)
  • Offline Folders file (.ost)
  • Personal Address Book (.pab)
  • Offline Address Books (.oab)
  • Command bar and menu customizations (.dat)
  • Navigation Pane settings (.xml)
  • Registered Microsoft Exchange extensions (.dat)
  • Outlook contacts nicknames (.nk2)
  • Rules (.rwz)
Aug 19, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
