Question about Samsung SGH-G600 Cellular Phone
Pin1 not allowed in samsung phone - what does this mean? How to get control of my phone back>
Forgot password samsung GT-C6712 ...How to open it?
If you forgot your phone code, what you can do is to have a hard reset. Hard reset means restoring the phone back to its original factory settings. if you do not do a factory reset, then you cannot change the code. It is the only way that you can change it. But on the other hand, this method deletes everything that you have saved in your phone memory. Including images, contacts, videos and everything on your phone memory. To do a hard reset on your Samsung GT-C6712, do the following steps:
1. Turn on your phone.
2. Open your dialer/dial pad.
3. Type: *2767*3855#
4. If there will be a confirmation message, just choose Yes.
5. Wait for the process to finish.
Note Use the code on your own Risk
you will lose all the contacts and private data
Note: After the hard reset, your phone will automatically reboot itself. If your device freezes after doing a hard reset, just do this:
Nov 24, 2014 | Samsung Gt-C6712
What is the network lock control key of galaxy s gt-19003
Do you mean the network unlock code? I suggest you can approach Mobile-unlocker.com and specify the country,locked network of Samsung GT I9003.Based on the availability you can get the unlock code along with free instructions.
May 11, 2014 | Samsung C3050 Cell Phone
Samsung gt s5233a unlock code
here are actually two codes that you can actually use to reset the password. Below are these codes. Please dial them up and have the problem solved.
  • *2767*3855#
  • *2767*2878#
This mean the security code will be reset to 0000. This will allow you to format the phone easily.
Oct 25, 2011 | Samsung Star GT-S5233 Cell Phone
Service not allowed samsung
On samsung wave go
Settings->Call->All Calls->Show my number-> "By network" has to be set for making calls If HIDE is set it will throw "service not allowed" when making calls!!
May 19, 2010 | Samsung F490 BLACK @GIFTS & BRAND @ Cell...
My phone M510 got wet and now shows offline - how do I change this
First of all, allow the phone to completely dry by removing the battery and sim card, and placing it in a warm (not too hot) location for 24 hrs. (do this ASAP)
If you're positive your phone is dry, go to settings > phone profiles, and select the 'normal' profile.
This should put your phone back into 'normal' mode. However, there is a chance the radio circuit got fried... (which means getting a new phone)
Dec 10, 2009 | Samsung SPH-m510 Cell Phone
Any advice for getting the usb cable to work properly with my Hue when trying to connect to my PC thru Alltell QuickLink Mobile? I keep getting the box saying the usb has malfunctioned. Have exchanged...
It sure is frustrating. USB has Malfunctioned does not necessarily mean the USB cable has malfunctioned. It could also mean the USB port in the PC. Go to Start->Ctrl Panel->System->HardWare->Device Manager. And check the USB Controllers right at the bottom of the list. Uninstall and reinstall the USB ports.
Aug 07, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Forgot the PIN1 code and the PIN2 code. How do I reset without calling my carrier?
try the defaults: 1234, 12345, 1111, 0000 this is kind of tricky so be careful
May 20, 2009 | Samsung T319 Cellular Phone
I have the T509-S Plum. When I try to dial, sometimes the phone freezes & I have to turn it off & then turn it back on to dial. Also, when I try to open my phonebook, sometimes there's an error message...
I have the same problem.
Samsung SGH-E250 on South African MTN network. Has been in for repairs more then 3 times and keeps doing, SIM does not do the same in other phones.
HELP!!!???!!!!
Andre Froneman
May 23, 2008 | Samsung Cell Phones
Samsung SGH-G600 Cellular Phone Logo
602 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
