Question about Kodak EasyShare V530 Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
  • Anonymous Mar 21, 2014
    The zoom on the camera is out and I can't power it on to get it in.
  • Anonymous Mar 24, 2014
    The lens just stopped working... I think it may have gotten stuck within one of the other lens.
  • 262 Answers
That error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Posted on Nov 12, 2009
My zoom will not come out, just clicks trying to come out.
Stuck zoom is the most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
This part can be easily replaced in most cameras.
The following video shows how to open a Nikon Coolpix P80:
http://www.desmontalo.com/?p=277
Apr 29, 2012 | Nikon Coolpix P80 10.1MP Digital Camera...
Zoom lens stuck closed
Here are some troubleshooting steps that you can try that may (or may not) correct your problem. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
And here's a video summary of the steps:
Dec 24, 2011 | Fuji FinePix A340 Digital Camera
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
My camera kodak easy share v530 has error e45 the zoom doesnt go in when i turn it off. when i turn it on it says error e45
E45 means it has a lens error., the gear of the lens is already defective you need to call precision camera for repair toll free 1 800 665 6515
Nov 01, 2009 | Cameras
Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Cameras
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
Kodak Easy Share LS443
hi there
the error is the zoom lens is stuck
there is a ring at the base of the camere which gets dirt in it and makes the zoom stick
can be repaired by most camera shops as it only needs about 5 screws removing to clean the ring
do not send it back to kodak because they will rip you off.
hope this helps
beergut707
Oct 22, 2008 | Kodak EasyShare One Digital Camera
Error E45
Turn your camera on and smack the camera against your hand. The E45 error means your lens is stuck. The lens on my V603 was stuck open, when I smacked it against my hand it closed and now works fine. Give that a shot.
Jun 23, 2008 | Kodak EasyShare V603 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Kodak EasyShare V530 Digital Camera Logo
449 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
