Question about ACDelco 3,500 Watt 6.5 HP OHV Portable Generator, CARB Approved #AC-G0002
ACDELCO 3500 portable generator will not start. Less than 1 yr ol
Brand new last year. Only used twice. Will not start now. It has been cleaned and properly stored.
  • cjolly Nov 12, 2009
    yes, new fuel
  • T C Swan Mar 19, 2013
    I bought this piece of junk from Northern Took 2 years ago. The Air Filter plastic case split after 1/2 hour and the carb broke down next . I've been doing without during Sandy and other storms. Why is it when I try to connect with Northern or Delco, I get , " Fix Ya > ; I can't get the parts , why
    President:
  • 3,433 Answers
Is it new fuel ?
Posted on Nov 12, 2009
Testimonial: "quick response, thanks"
  • 2 more comments
  • Ned C Cook
    Ned C Cook Nov 12, 2009
    Be sure to drain the carb of old fuel.
  • Ned C Cook
    Pull the plug(s) and dip the tips in gas and reinstall and try starting.
  • Ned C Cook
    Taking the plugs out resets the grounding through the threads and wetting w/gas gives it something to ignite with the weakest spark.Once it starts everything will shape up. Run it for 1/2 hour to chase all the spidersout. "working out the bugs?:-)
  • Ned C Cook
    Ned C Cook Nov 13, 2009
    Did you get it lit? Just fllowing up, Ned
Started to stall twice while driving then did stall and has not started since
What is year--make--model? Make sure battery has a full charge and battery connections all good.
Does it stall at idle or going down the highway? How long since a tune-up? Can you check for applicable trouble codes? Some of the national brand auto stores will check codes for free, if there are any. Depending on your model year, you need a code reader, at the least, that will work with your vehicle, to check codes. If your obd1, you may not need a code reader.
If it cranks good but won't start, have a helper crank it, while you check for spark at the spark plugs, gasoline engine. If spark everywhere, use a gage and check proper fuel pressure and fuel injector pulse, where applicable.
Mar 04, 2016 | Cars & Trucks
Fridge stopping and not starting unless i will switch power supply off then on again
when was the last time you pulled the front grill at the bottom and cleaned it out? or had it serviced, most times they come in with a air compressor and blow the coils free and everything is back to normal, I clean mine twice a year, have a special 20 dollar tool bought from parts store.
Apr 30, 2015 | Refrigerators
Left gas in my HOMELITE UT10516/16 in. 33cc. chain saw FOR LAST 2 YEARS. WHAT TYPE OF CLEANING WILL I HAVE TO DO TO GET IT BACK IN RUNNING CONDITION?
Get an overhaul kit for your carburetor. Rubber parts need to be changed not simply cleaned. Gasoline handled properly will clean the carb or you can get a spray on product from any auto parts store.
Jun 04, 2014 | Homelite Garden
Vacume does not **** hoses are clean
If it is not cleaning the floor properly start by installing a new belt. Belts should be replaced at least twice per year even if they look ok and the brush roll seems to spin. They lose elasticity and will not clean properly.
Mar 04, 2014 | Riccar 8850 Vacuum
How do I fix my push mower with a Briggs & Stratton engine?
Its obviously a fuel starvation issue, so there is still some blockage in the carb, re move the carb and see if your frendly local dealer will clean it in there sonic cleaning tank, if not soak with carb cleaner and blow the jets through.
May 11, 2012 | Garden
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had...
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Mar 28, 2011 | Heating & Cooling
Brand new echol pb250 leaf blower. used it twice then hard starting afterwards
Hi, Check that your air filter is clean and that the choke is set properly. Otherwise make sure your fuel mixture is accurate. Hope this helps.
Nov 15, 2010 | Echo Garden
Last year around this time I tried to start my
Carburetor is probably gunked up from old gas left in system. It will need some cleaning and / or dissasembly.
Have it repaired at a reputable mower or small engine repair shop. When being stored for long periods, run it out of gas or use a fuel stabilizer in the gas to prevent this from reoccuring.
May 13, 2010 | Honda 2500 PSI Gas Pressure Washer
Door light, on/off switch, water and ice dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it.
if you are still having trouble please respond with a model number
Apr 15, 2009 | Refrigerators
ACDelco 3,500 Watt 6.5 HP OHV Portable Generator, CARB Approved #AC-G0002 Logo
433 people viewed this question
Top ACDelco Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an ACDelco Electrical Supply Expert? Answer questions, earn points and help others
