Question about HP DeskJet 3550 InkJet Printer
My deskjet 3550 printed its test sheet and now goes through the motions without printing anything ie ink does not go on paper
    Problem Solver:
  • 18 Answers
make sure that u ink in the cartridges, u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Posted on Nov 12, 2009
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam< endliamc@gmail.com>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
No black ink is appearing on paper
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
Jul 30, 2009 | HP Officejet 5510 All-In-One Thermal...
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Hp 3550 printer color cartridge printing but black not printing
Perform print head cleaning and also try to take a test page and ensure that ink is properly injected out of nozzle.
If this doesnot work take out the cartridge and clean the contact and reinsert the cartridge .
Jan 30, 2009 | HP DeskJet 3550 InkJet Printer
HP 520 Desk Jet printing garbage
fot resolve this issue you should try that get a self test print ,( demo print) if it is good you have a software problem and also you should install the dirvers . if the demo test print is not good you have a hardware problem about carriage and ink system and you have to replace the carriage system.
Jan 26, 2009 | HP DeskJet 520 InkJet Printer
Paper not feeding in
I too have a problem with 3550 desk jet. My printer most of the times not sending my papers in a good form, it is either tored or hanged. If sent properly the printing either missed or lines merged or gapping abnormally. Pl tell me a way out to my email ID
mvraghavan@hotmail.com
Jan 05, 2008 | HP DeskJet 3550 InkJet Printer
Deskjet 930c printer
Good for you for being on the internet and posting the question! The yellow light usually means, paper, ink or a jam. If it's got paper and ink, check for jams and even power cycle it and see if that helps. And try printing, it may just be reporting low ink. Good luck!
Jun 09, 2007 | HP DeskJet 930c InkJet Printer
HP DeskJet 3550 InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
