Question about LG 42PX5D 42 in. Plasma HDTV
I have lost the pedestal stand were can i get one
    President:
  • 1,284 Answers
Here is a link to purchase the stand. For some reason they have the description as a board..
http://lge.andrewselectronics.com/search/electronic-parts/parts/9/3501V00216A.aspx
Posted on Nov 12, 2009
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Where can i find a stand
If you're referring to the original pedestal base sold with the TV, your best bet would be Ebay
or Craigslist.
On Ebay, search in the Category: Electronics > A/V Accessories & Cables > Mounts & Brackets >
using the search string "vizio 50 pedestal stand" or "vizio pedestal stand base" and you should get a few matches. For example, this used pedestal stand, which has a current bid of $9.99 USD, or this new pedestal stand, being sold for $149.99 USD or Best Offer.
Hope this helps!
Jan 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
I need a pedestal stand for an LG 47" FULL HD,
Tries websites like Amazon.com,Ebay.com to buy an a used or new LG pedestal stand.
Nov 06, 2010 | LG Televison & Video
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
LG 42PX5D 42 in. Plasma HDTV Logo
163 people viewed this question
Computer Repairing
Computer Repairing
