Question about Cell Phones
My 2 gb media card wont work in my verizon rival
My 2 gb media card wont sync my music. to my verizon rival
Sync itunes
Launch iTunes.
Connect your media player with SanDisk memory card installed to your computer through its USB adapter.
Wait for the player's device icon to appear in the iTunes Source pane.
Drag and drop music titles from the library pane directly onto the device icon.
The music will sync onto the player's SD storage.
hope this helps
Sep 17, 2012 | SanDisk Cruzer Glide - USB flash drive -...
When i plug an lg usb cable into my computer and my motorola rival to sync music "unauthorized charger" appears and it wont work
You have to have a Motorola Rival charger to charge the phone. You also need it to sync to the computer. The Motorola Rival is a feature phone, so it's strict with the chargers it uses.
Jan 19, 2011 | Cell Phones
My blackberry bold 9650 is reading my scandisk 8 gb media card as a 4 gb media card. This just started happening. I found the problem when syncing my music. All of my music on Itunes used to fit on the...
joel paterso,
I will list a couple of suggestions that you may already know about, but hey anything is better than nothing, you'll go away knowing you tried everything.
1. It could be that the memory card is now corrupted, in this case there is no hope just buy a new on from ebay, thay are alot cheaper there if u can wait a week or so.
2. It could be that the software is only recognizing "free space" so don't worry. you still have 8GB of memory. Maybe there's a compatibility issue with the blackberry software recognizing your music. I don't think there is a major problem with anything here.
3. You could try erasing the music off of it to see if the software will recognize it as 8GB, if it does then its because of reason #2
There you go Just my thoughts as to what you could do to troubleshoot you issue. If you have anymore questions just let me know!
-hopeufixit-!
Dec 01, 2010 | Cell Phones
My motorola rival wont sync my music from my 2gb sd card.. i neeed help!!!! email me at mrsmassey@ymail.com
The Problem might be in the bitrate thats to high,use a converter and bring down the bitrate to 128 and that should help ur problem
Nov 20, 2009 | Motorola Mobility Rival A455 Cell Phone
I have a question how do i put music on my phone if the sync window for media player don't show up?
use a mine sd card download music to windows media then sync on the sd card then put that card in your phone and then go yto you player and once there go to update library and it will move the music to your phone hope this helps
Sep 21, 2009 | Motorola Mobility Rival A455 Cell Phone
Motorola phone tools 5.0.1 won't sync my A455 Rival. It says that my phone is not supported, i'm trying to put music/ringtones on my phone and am using the usb cord
Thank you for contacting Fixya!
Problem: Transferring Music from Computer to A455 Rival Phone
Solution:
You can use the Micro SD card to transfer music and other media from your PC to the phone, and vice versa. The microSD card must be inserted for you to be able to view the storage card menus.
The A455 does support the MicroSDHC card.
The Rival can support up to an 8 GB Micro SD card.
Copy and paste this URL into your browser for further instructions. http://alturl.com/zn6q
Aug 30, 2009 | Motorola Mobility Rival A455 Cell Phone
How do you get music on your verizon phone without paying monthly
Using your supplied USB cable, connect your phone (after installing the drivers) to your computer.
On your phone, goto "My Music" and click on "sync".
Option 1:
Your Windows "Portable Device" connect pop up should appear.
Double click on "Sync digital media files to this device..." OR
Jan 05, 2009 | LG Dare VX9700 Cell Phone
Can't sync music onto MP3
Hi Jollie17,
Try downloading the free version of real player and use this to sync your music files. It helped me. Take care.
Jun 29, 2008 | iLO (2 GB) MP3 Player
Saving songs on sd memory card
1. Put a micro SD card into your phone. (Make sure it's blank)
2. Format the card from your phone. To do this go into "Menu//Settings & Tools//Memory//Card Memory" then click on "Options" that should open the format screen. Enter your security code (usually the last four digits of your cell #) and format the card.
3. Exit all menu screens by pressing the "End" button and remove your card.
4. Insert your card back into your PC. It should recognize the card and open a "Removable Disk" window. (if not, manually open this window by clicking on "Start//My Computer//drive E: or F:" , they might vary depending on your computer set-up.
5. You should see a folder named "my_music". That's where you are going to drag your music files into.
6. DO NOT open any media player. Just find the location of your music FILES. Usually if you click on "Start//My Music" your music FILES will be stored there.
7. Simply drag and drop music FILES into the folder that I listed on #5. DO NOT drag an albulm. It won't work. Just the music file.
Jan 21, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
