Question about Car Audio & Video
The light on the radio of my fiat brava stays on even when the radio is turned off and it drains the battery. Can you help me? Thank You
  • ckadampinbal Nov 25, 2009
    Thank you for the response,
    My concern is that the problem started with nobody messing with/removing the radio. I have since tried the radio in my fiat punto and the same problem occured.
    Thank you
    Christophe
  • 117 Answers
Someone put the memory and "switched " wire in the same power source , usually yellows "constant" and reds "switched" see in there if those wires are tgether coming from the radio, if so, seperate them then use a 12 volt test light to fuse box while turning cars key on and off till u get a flashing action from the test light .... thats youre switched source
Posted on Nov 25, 2009
My temperature gauge is not working despite having having new one installed. Thermostat when connected fan doesnt work when engine heats but when you dosconnect thermostat fan works immediately engine turn...
faulty thermostat switch ,does happen even to the best of us ,buy a new one then find thats faulty as well just buy another as they are not expensive
Apr 25, 2011 | Fiat 500 Cars & Trucks
Battery not flat but wont even tick over ,we know starter motor ok but when my husband turned the ignition key a spark came from below the battery the car is a 1998 fiat brava 1.4s
try to take o look att the ground wire from the battere to the car chassi and from chassi to engine, and do a load test on the battery to. good luck Hans
Jan 14, 2011 | Fiat 124 Cars & Trucks
Hi i have a fiat brava car and need to unlock the radio, i have the code,
Quote the radio MAKE + MODEL and find the instructions on this free website
http://www.radio-code.co.uk/code-entry-help.php
Jul 19, 2010 | Car Audio & Video
How you put fiat brava radio code in
It depends on the MAKE + MODEL of your radio.
A collection of free Code Entry Instructions can be found here
Mar 14, 2010 | Car Audio & Video
Hi ihave a fiat brava 1.2 x reg in the morning the car will not start it turns over rather lazy and only 2 or 3 turns and the digital clock trip meter reset to zero.it has new battery earth wires ok...
It seems the battery loses power over night.
There seems to be some electrical componant chewing up the battery.
Try to remove one of the battery terminal wire at night and thn fix it in the morning and thn see if it will start without jumping, if it does thn the battery is being chewed up overnight.
If after removing the battery terminal at night and refitting it in the morning and it still requires jump start ,thn the battery is faulty.
Hope this helps!
Nov 24, 2009 | 2006 Fiat 124
Fiat brava oil warning light wont go off
<grin> I don't know why or how this ended up under the category of Fiat 2006 X1/9 - I'd like to have one but I think I will have to be satisfied with my '87 Bertone instead-
I would highly recommend you have a shop replace the sensor (very soon!) with a pressure gauge to measure the pressure directly to make certain you aren't dealing with a failed or obstructed oil pump. This will only take a few minutes and shouldn't cost much. If your engine isn't clattering, I suspect the replacement sensor isn't any good either.
Oct 24, 2009 | 2006 Fiat X1/9
Oil warning light on a brava car wont go off
Best would be is to measure the oil pressure out put.
Sometimes the oil filter could be the culprit.
Was the oil warning light staying 'on; prior to the oil and filter change?..If not thn the first thing to check is to replace the oil filter ..its better to install the 'original' one .
Hope this helps!
Oct 24, 2009 | 2006 Fiat Strada
Timing belt problem on fiat brava
i recomend you to buy a book with the timing marks because i had the same problem and i have one of the best repair information software online and that could not even help me
this type of car has to many marks and you need to make sure where they go, but if the timing belt still complete and in the car all what you have to do is mark it with liquid paper or some kind of ink and put it back the same way
May 29, 2008 | 2006 Fiat 124
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
Nov 19, 2007 | USA Spec SCD-A88 6-Disc CD Changer
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
