Question about Onkyo HTR500 Receiver
What is remote code for ht-r510? i want to control my HT-R510 with a newer and different remote control.
5 Suggested Answers
  • 5 Answers
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
Grubhead
  • 5126 Answers
SOURCE: Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Posted on Mar 21, 2010
ThePoodleGuy
  • 24 Answers
SOURCE: Sound not working on onkyo ht-r510. It Powers on
Simjones700,
Assuming that everything looks like it should work, that the volume is up sufficiently and the mute is off, and that any power section fuses are set and/or not burned out and that the units 'warm up' temperature feels the same. I would try a process of elimination something like this:
* Always turn the unit of and unplug it everytime you attach/detach speaker wiring *
Unplug all sources (DVD, CD, DVR etc) and use only the FM section as as source:
  1. Does the unit have an indicator that is labeled overload or protect or something like that? If so, then unplug/disconnect and inspect the wiring on the speaker terminals. Ensure that if they are bare wires, there are no strands from different wires contacting each other.
  2. Does the unit have a speaker have an A/B switch? If so, ensure that your speakers are plugged into the correct terminals
  3. Does the unit have earphone plugs? If so, try using those . . . if you don't have any earphones go and purchase a cheap pair . . .make sure you have the proper plug - 1/4" stereo?
  4. Do you know for a fact that your speakers work? Beg, buy or borrow a pair of cheap of speakers and try them.
  5. Try using different speaker wire . . . if you have a fancy monster or vampire wire wiring set up, then go to RS and buy some in-expensive speaker wire (not too thin!) and see if anything changes.
  6. Unplug everything from the unit and then hook up one and only one speaker and see what happens. Move the speaker wiring from one set to another, see if there is any behavior change . . .
If after all this and no joy, then time to take it to be serviced.
The Poodle Guy!
Posted on Nov 25, 2010
AJIN G
  • 6694 Answers
SOURCE: i lost my remote control
HI,
Press the SPEAKER ADJUST button on the frond panel of the receiver. With this button you can select different parameters of the speakers. Using the PRESET/ADJUST button you can change the parameters.
ok
Posted on Sep 24, 2011
Want to control my HT-R510 with my TV remote. Need Onkyo code to control this HT-R510
You should indicate you remote.
In any case, if code is not in your remote you should follow indications for No code
If you don't have a manual, look for one using google,and terms manual, make and model of your remote
Aug 26, 2015 | Onkyo Audio Players & Recorders
Intermittent speaker performance - receiver issue - not a speaker issue
Matt,
Have you checked/cleaned the leads on each speaker as one bad lead or speaker can pull/push extra power from/to other speakers causing shorts, this is likely not the case but could be the easy fix. Try cutting one speaker out at a time rotating which one is disconnected to see if this fixes the issue and possibly points out either a bad speaker or connection.
Dec 04, 2013 | RCA Onkyo Ht-r510 Receiver 6.1 Channel...
Onkyo HT-R510
have you tried to reset it to factory defaults yet? If it has a vcr button on the front, then hold the vcr button and press power...it should say reset on the front. Might not help, but worth a try.
Dec 04, 2013 | Onkyo TX-SR601 Receiver
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
Nov 29, 2012 | Onkyo Ht-r510 600w 6.1 Dts Home Theatre...
I lost my remote control for my ht-r510 and i want to reset my speakers volume, how can i do that manually?
HI,
ok
Sep 24, 2011 | Onkyo HT510 Receiver
How do i put new keyboard in my samsung r510
This is not a "do-it-yourself" job. Take the Samsung to a qualified technician, to get the job done correctly, without damaging your device.
Mar 06, 2011 | Samsung R510 AS08 R510 FA01 R510 FA02 R510...
Mar 21, 2010 | Onkyo HT510 Receiver
Dec 04, 2009 | Onkyo TX-SR501 Receiver
Onkio receiver
The output transistors should be replaced in pairs. Also, It may not be just the output transistors that are defective. If you have no experience with these types of repairs, I would suggest that you bring the unit to a service shop. The outputs will run about $15-$25 per pair.
Dan
Aug 29, 2008 | Onkyo TX-SR601 Receiver
Onkyo HTR500 Receiver Logo
222 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
