Question about LG Dare VX9700 Cell Phone
Colors on pictures have red outline - LG Dare VX9700 Cell Phone
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
Blurring of lettering on bottom of screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 15, 2010 | Philips 60PP9202 60" Rear Projection...
The picture has a red shadow outline
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
You can see some more examples and find a fix here
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
LG Dare VX9700  Cell Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
