Question about Sharp FO 5700 Plain Paper Laser Fax
Our Sharp FO-5700 fax machine is broken. How do I
Our Sharp FO-5700 fax machine is broken. How do I forward to another fax machine?
  • qpura1 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
5 Suggested Answers
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
  • 75 Answers
SOURCE: FO 5700 Won't print from memory
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
Posted on Feb 03, 2009
  • 48 Answers
SOURCE: Sharp FO 5700 - Please Wait For A Moment message
Hold down the stop and start key while turning on the fax, let go when you see 1 for yes 2 for no for memory clear. Press 1.
Posted on May 25, 2009
  • 48 Answers
SOURCE: can send but can't receive faxes.
Make sure its on standby auto not manual.
Posted on May 28, 2009
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Tip
How to get the page count for a Sharp FO-5700 fax machine
Sharp makes a line of fax machines, one of which is the FO-5700. The FO-5700 is easy to maintain and to use, and it can run well for years. If you want to view the life counter (page count) for your FO-5700, just follow the steps below.
With the fax machine on and ready, flip up the bar that displays the information for half of the quick dial buttons (#17-32). This bar has a tab that you can use to flip it, which sits right by the panel release lever (where you would put your hand to raise the operation panel if you had to remove a paper jam there). Just flip this bar up so that it covers the first half of the numbers instead of the second.
Once the bar is flipped up, you'll see that the V button is labeled "Life." Press that button to bring up the counter menu. Then press 1 on the fax machine's number pad. The screen will display "1: Life Counter" and below that, "LIFE=xxxxxx" where "xxxxxx" is the page count of the machine, in six-digit format.
You can view this life counter at any time, without having to print out a configuration page or usage page. To exit out of the life counter screen and return to the main screen, press the red Stop button. Be sure to flip the contacts bar back to its original position; there is a sensor that detects which way the bar is laying, and if it's still in the up position, pressing a button will have a different effect than it would if the bar were in its original position (such as bringing up the life counter instead of dialing a number).
on Jun 12, 2011 | Sharp FO 5700 Plain Paper Laser Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
3. press start
let me know
good luck
Jan 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sep 08, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Message that tray is out of paper, and tray is not in machine.(SHARP FO-5700 Fax)
Go underneath the machine and make sure that a black piece of plastic is secured in there. Sometimes they get pulled out when the tray gets removed.
Jul 01, 2008 | Sharp FO 5700 Plain Paper Laser Fax
SHARP FO-5600 - THE MACHINE HAS AN ERROR MESSAGE IN THE DISPLAY AREA "CLEAR TONER COUNTER". I CANNOT FIND ANYTHING IN THE MANUAL ABOUT THIS MESSAGE
CDURHAM,
I found the answer to this on page 22 of the PDF manual that can be downloaded from http://www.sharpusa.com/files/fax_man_5700.pdf.
May 06, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Sarp FO-5700 it doesn't noved.
Can you do a copy?
is paper tray in base of machine up or down?
Are drum and toner ok?
Do you have network card attached?
How do you know that fuser is ok?
Nov 04, 2007 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO 5700 Plain Paper Laser Fax Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
