Question about SKS Rifle High-profile See-thru Scope Mount W/1" Rings
When the rifle cycles and ejects the empty brass it is getting bent at the neck. The rifle is scoped and i think the empty is hitting the scope. can the rifle be reworked to throw the empty more to the side so it doesn't hit anything?
  • 3 Answers
You can purchase a shell deflector from many stores such as "Ceaper than Dirt; Or Sportsmans Guide each on the internet.
Posted on Feb 21, 2010
    Problem Solver:
  • 17 Answers
If you really want to you can attach a deflector plate.
It would be something you will have to make yourself
Robbie
BSA owners group
Posted on Nov 19, 2009
  • BSAultra Nov 23, 2009
    Are you using the brass for re-loading?
    President:
  • 2,702 Answers
Not realy i would sergest using a diffrent mount
Posted on Nov 17, 2009
Why doesn't rifle eject shells?
Extractor claw spring or claw worn out of tolerance
Shell expanded to much in chamber and sticking
Chamber throat worn and neck of case moulding to lock in case to the chamber
Jan 18, 2016 | Optics
308 handy rifle wont eject
Take it to a gun shop and they'll inspect it, could be just dirty or something got bent.
Mar 06, 2015 | Optics
How do you mount a scope on a model 94 winchester with a side mount so it will eject
you have to get the gun drilled and taped for a side mount scope. they make them for the top eject Winchester.
Feb 13, 2015 | Winchester Model 94 Short Rifle .30-30 20...
Manual bushnell sportview 3x-9x.32 scope
The Winchester 94 ejects the spent cartridge straight up and out of the top of thr receiver. This nesesitates mounting a scope off to the side to avoid jamming the action with a spent case hitting the scope and failing to clear the action.
Jun 29, 2012 | Bushnell Optics
Why does my 30 yr old redfield, widefield ,range finder accu-trac scope that has operated great for all these yrs, now I cain,t get it hit in the same zone a target. The rifle is clean and operates great...
well if the bullet hit is jumping about its all down to your scope,,,it could be that its just "lose on its mount!" or its died on you,,like the cross hair is bouncing about inside the scope so with the recoial it jumps into a new place with every shot fired there by giving you a new point of impact,,,
this can happen if the scope was wound right up or down or left or right and strain was put on the adjusters,,,you may need to buy a new scope,,,,a good "air rifle!" scope will work quite well on most full bore rifles,,,yer right i here you say!!! ok,,iv got air rifle scope's on my .303 + 7.62 + 22-250 + .357 under leaver marlin cowboy, all 3 of my .22 rim fire's and they have been on these rifles for years now,,,1000,000, of rounds fired so far, with no problems! and no drifting so far,,,
an air rifle scope is very strong you know,,,but they only cost £150,00p or less for a good one?????
ps,,,,dont buy a tesco scope there cra*y
Nov 22, 2010 | Redfield Optics
Tlescopic sight
I couldn't find the eurohunter model, but I checked out the website. Without a bore sighter, You can still get your scope to hit a paper plate at 100 yards by using a cardboard box. Then it will fine tune in just a few rounds. Only a bolt action though, you have to be able to see down the bore. Take a big box, or a rifle vise, cut some V's into the top edges, lay the rifle in there, pull out the bolt, find a target 100 yards away, put the bore of the rifle on it and don't move the rifle. Then put the crosshairs of the scope on the same target, check to make sure the rifle didn't move, then check the cross hairs again. You will be able to hit your target at 100 yrds, the ar 15 is an exception to the bolt action, you can see down the bore.
Feb 11, 2010 | Nikko STIRLING EUROHUNTER RIFLE SCOPE --...
Which knob on the bushnell banner scope will raise the bullet when it is hitting six inches low?
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that same spot.
To move the scope's reticle up or down, turn the adjustment on the TOP of the cope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
Hope this helps, Mark the Gunsmith
Dec 13, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Simmons scope that will not stay on target
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Mar 02, 2008 | Optics
SKS Rifle High-profile See-thru Scope Mount W/1" Rings Logo
163 people viewed this question
Top SKS Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a SKS Optic Expert? Answer questions, earn points and help others
