Question about Sunfire True Sub MK II Subwoofer
My sunfire subwoofer starts making humm noise after a couple minutes while listening music,,, I have to disconnect and connect back, is something that involves equipmenrt adjustment?....thanks
  • 4 Answers
Sunfire used low quality electrolytic capacitors. As those capacitors fail, a hum develops, eventually it can even blow the output transistors. In other instances it simply silences the sub. No signal gets through to the output. Beware of the Jun Fu capacitors. I'd use Panasonic low ESR or Nichicon low impedance capacitors instead.
Posted on Sep 27, 2012
Try plugging the unit into a clean power supply without anything else on it. I had this problem for years and eventually resolved it by moving the system to a different room that has three power circuits - the sub is now on it's own circuit and I don't have the problem anymore.
Posted on Nov 28, 2009
  • 3 Answers
Just recapped, I hope that noise goes away. BTW- does anyone know how to repair either the Junior or the Architectural? Need some help here because the output FET's and transistors are all blown.
Posted on Jan 11, 2013
Emachines laptop keep freezing and making loud buzzing noise when i listen to music. please help
The buzzing/grinding noise is probably a bad connection if you are using earphones. Put a couple of drops of rubbing alcohol on some toilet paper and clean the prong for your earphones. Wait a minute and reinsert the plug into the jack. As for the freezing up of the video, you might want to download and install your video drivers for your emachine. Go to the manufacturer's web page to find the right ones. Don't forget to reboot after installations.
Feb 28, 2014 | Acer Genuine Emachines E525 E625 E725...
My sub woofer humms when idle
The humming could be a couple things.. First try a different outlet in a different room..Make sure the RCA is firmly in place if using LFE and none of the speaker wires strands are touching if using Hi-Lvl input. Also if using Hi-Lvl you might be getting feed back from the Amp.
Apr 07, 2011 | Sunfire True Sub Signature Subwoofer
Sub has started humming with amp turned off. just turned on at wall switch.nothing running
If the hum is from the back of the unit around the amplifier, it may be the transformer. It could be that the mounting is loose.
It could also be that the transformer is going out.
Disconnect all the inputs to the unit, Still hum?
If the hum stops you have something causing noise to the input.
If you have it on a switched circuit, try moving the power plug to a different outlet that is not on a switch. If hum stops, then you have something on that circuit causing the problem
if all inputs are disconnected and it still humms good chance it is the transformer.
Nov 12, 2009 | Velodyne CHT-8 Subwoofer
Rattling sound with any significant base output
You either ripped your voice coil, or you have something jumping around inside (Screw, nail, etc.). You can tell of a blown speaker by pressing straight in, and if you hear a rubbing noise, then your speaker has disconnected from your voice coil. Mickey mouse jobs include Krazy Glue, but It's touch and go
Sep 02, 2009 | Sunfire True Sub Signature Subwoofer
Sunfire annoying popping noises
If you remove the volume knob, and tighten the nut below, it should take care of the popping noise, as well as any input noise issues. Based on my experiences with my MKII
Apr 01, 2009 | Sunfire True Sub MK II Subwoofer
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
PROBLEM WITH SONY WOOFER
This must be cable connection problem. There may be loose connection or cable is not working properly so change the cable and enjoy. Thanks
Aug 10, 2007 | Sony DAV-DX255 System
Sunfire True Sub MK II Subwoofer Logo
1,138 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
