Question about Bosch HDI7152 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Bosch "slide in" doesn't slide in.
I have a slide in that doesn't slide in. The Bosch HEI7282 has a decorative piece that juts out from the top right and left to make that part 31 inches wide. This hits my countertops (they are not flush with the counters, which I assume is why I'm having this problem - but the range is not advertised as being only for flush countertops). Because of this the range is about an inch too far forward, exposing the sides. Has anyone seen this? I'm getting nowhere with Bosch - they tell me I need a professional installer (to push a box into a hole?)
3 Suggested Answers
  • 22 Answers
SOURCE: installing the Bosch HDI7152 slide in with a bull nose counter
I need to see a picture of the condition you are talking about before I make a suggestion.
Posted on Dec 04, 2007
  • 457 Answers
SOURCE: We have a Bosch range top built into our counter
there is 4 switches in there some time in sequence. it has to dried out with blow dryer or replace the switches .the front knob toeplate has to be removed also the hob has to be removed.nyc appliance repair is agreat company to handle this situation.
Posted on Feb 26, 2010
How replace shoe clamping piece on Bosch 1590evs jigsaw
At the rear of where the tool body attaches to the base you will find a black thumb knob (#823). Flip the shoe release lever (#828) open then loosen the thumbscrew until the base comes off - the lever will then slide right out. Bosch 1590EVS 0601511739 Top Handle Jig Saw Parts
Jan 12, 2017 | Bosch Saws
Rm-yd029 sony remote mute button not working
Hopefully this isn't too late for you. It will at least be available for others who face our problem.
Step 1: Remove the battery cover.
Step 2: Remove the screws that are under the battery cover.
Step 3: Remove the sliding panel at the bottom of the remote. Gentle pressure under the center of the door will lift it over the retaining tab. You might have to apply a little pressure on one side of the door to get it to release. Again... GENTLE.
Step 4: Work a very thin screw driver into the small gaps at the bottom of the remote in the area that was under that sliding door. I used a jewelers screwdriver. Gently work the blade around and back and forth until you hear a tab pop. Then get the other side's tab to pop. Use fingers and blade to get that end segment to pop open.
Step 5: Carefully work your way up both sides of the remote with the screwdriver releasing tab after tab. You can pop one on one side and then go after the matching one on the other side. Sometimes you can do two at a time on one side before doing the other side. Try not to apply pressure on the silver/gray side trim. It is decoration only. Get the blade in between the black top piece and the black bottom piece to pop them apart. Do this along the sides up to the top.
Step 6: The retaining tabs that are at the very top of the remote can be released with a gentle pulling apart and slight twisting of the top piece and bottom piece. Everything should be open and the layers should come apart easily.
Note: Be aware that the plastic frame parts on the big circular pad in the center of the remote face may fall out when you pull things apart. Not a big deal. Just make sure you reassemble it correctly. Be patient and look closely at it. It goes together pretty much one way and has sized tabs that help to get it right.
Step 7: Do whatever cleaning you need to do. For my situation, some liquid had gotten into the volume control area. I used a q-tip to clean it up.
Step 8: Before snapping it back together, fit all of the layers in the bottom piece then do a test of the buttons to make sure they work. (Replace the batteries if you removed them, of course.)
Step 9: Assuming all of the buttons worked and you are ready to reassemble, transfer all of the layers into the top piece (best done with the top piece upside down) and make sure they fit well. Make sure the two silver/gray trim pieces are firmly in place on the bottom layer. Hold the upside-down bottom piece above the upside-down top piece and snap the bottom piece into the top piece.
Step 10: Recheck that the buttons work. Re-open and try again, if necessary.
Step 11: Assuming all the buttons work, replace the sliding panel from step 3. Get its tracks aligned with the remote's tracks and it should be a simple pop in. Heavy force is not necessary.
Step 12: Replace the screws
Step 13: Replace the battery cover.
Hopefully this worked for you.
Aug 19, 2012 | Televison & Video
HBN13B2613
Built in ovens fit into a unit and are not free standing so no it doesn't have legs
May 22, 2012 | Bosch Ovens
What are the decor strips used in the Bosch dishwasher? Are they important to use? Will the gap between the sink cabinet and the dishwasher be wider if you use them and have a wood decorative panel?
They are to provide a moisture barrier to protect the cabinets from damage. They are also used in some cases for cosmetic purposes. But is more for the moisture that can rot out or damage wood under the counter tops.
May 14, 2012 | Bosch Dishwashers
My GE TFX22Z has served me well over the years. Recently, I noticed that the refrigerator side door has lowered about 3/4 of an inch when compared to the freezer side door. In other words, they no longer...
from the description given I came up with;
possibly the screws are lose on the top door hinge, the top or bottom hinge is worn, the door is warped or damaged.
Aug 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I accidentally mixed up the left and right front wheels when assembling the stroller. How do I get them off to re-install them correctly?
Hi
Perhaps you can find one or two small pieces of plastic (underneath) you can push back in untill the bracket can slide over and from the tubing.
Hope this helps, for I don't actually have Britax in stock.
Apr 21, 2011 | Britax B-Nimble Travel System Stroller -...
I have a Bosch HEI7282U range. Went through self clean cycle, oven cooled down but oven door will not open. Put through another self clean, door still does not open. Cut power at circut breaker for over 5...
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut
Jan 31, 2011 | Bosch HEI7282 Electric Kitchen Range
Clogged drain tube on Bosch Axxis condensing dryer
just after having the same problem on my Bosch condenser dryer, remove the top cover by removing the two screws on the rear panel, slide the top cover aft to remove it. when the cover is lifted clear you will see where the drain hose to the collection container is installed, look at the aft l/h corner, you will see a black hose comming up through the corner which attaches to a white plastic end piece which is clipped to the frame of the dryer. Release the clip which hold the white end piece, pull the end piece from the hose, there's a good chance that the end piece is block with fluff etc, blow through from the opposite to clear any blockage, blow through the hose to make sure that its not blocked also. Hopefully this will cure your problem , rebuild in reverse order ----- Hope this helps
Jul 25, 2010 | Bosch Axxis WTL 6106 Electric Dryer
Need to remove decorative door panel
There are two main ways to remove it.
  • There should be screws on metal trim the side and or bottom of the dishwasher door. Take those out and it should come right off.
Or
  • There are screws on the back of the door screwed in to the front of the door. Remove the screws and it should come off.
Now this is say IF it was installed properly and not clued or screwed on by just anyone.
Good luck. I hope this helps.
May 30, 2010 | Bosch SHV68 Built-in Dishwasher
We have a couple of brutes that hit slow, I've tried rebuild kits, field coils and armatures. None of these seem to work. Amp drawn normal. Any Ideas???
Sounds like you have too much suction in the hammer cylinder. The hammer may be getting stuck at the top of the cylinder. Inspect to see if the hammer beat piece will slide out of the hammer cylinder. There may be too much grease behind the hammer causing suction at the up stroke. There may also be scarring inside, so inspect to see if the hammer beat piece slides smoothly. Hope this helps.
Jun 26, 2009 | Bosch Brute Breaker Hammer 11304
Bosch HDI7152 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
88 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
