Question about Sony Cyber-shot DSC-W80 Digital Camera
The display on my camera tends to sometimes move erradically when using the zoom. The error message E:62:11 also flashes on the screen.
5 Suggested Answers
  • 104 Answers
SOURCE: sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Posted on Feb 07, 2008
SOURCE: Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Posted on Mar 18, 2008
  • 586 Answers
SOURCE: Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Posted on Jun 27, 2009
lock123
  • 6831 Answers
SOURCE: sony mavica digital camera error message 61:10
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Camera zoom does not work
that is an error condition on the lens
take it back its jammed
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Reads zoom error when turned on
The device requires restoration achieved in two processes
perform a check
1. Power off completely the camera.
2. Remove all power devices or batteries
3. Check the entire device for damages
4. Make observation notes about any malfunct features
5. Replace batteries and removeavble parts properly with caution that every feature is intact.
6.If the device still displays error message consider the second phase explained
a. The device program features are jammed only possible solution is performing a software update or upgrade
1. updates are achieved by contacting the device;s technical support deparment
2. Upgrades can be performed by acquiring an installation kit in which instance requires technical expertise to perform an intergration restoration
Important notes
1. Apart from the message received does the device malfunction?
2. Your camera would be displaying an image similar as flash screen or screen saver that can be fixed quiet easily
a. use the menu buttons to select the option of settings
b. set the picture to be displayed on the appears screen area once powered on.
c. Possibly alter the entire image displayed as desired by yourself.
4. A screen saver could only be deleted,, hidden, or replaced with a preferable image
5. Possibly, the words ZOOM ERROR could changed to WELCOME TO OLYMPUS STYLUS
Refer to the camera manual for diagnostic support
Dec 02, 2010 | Olympus Stylus 730 Digital Camera
Moves erradically on screen
Change the battery. then re-sync the mouse
May 06, 2009 | Computers & Internet
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
E 18 Message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Sony digital camera dsc s40
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
System Error message
So you have any other memory cards? You may want to try that first. What batteries are you using? Can you try a new set of NiMH batteries? not alkalines but NiMH try these things first because they are easy. If you have tried different memory, and different batteries then it could be a connection problem inside the unit. These cameras dont have may circuit boards so they use ribbon cable to connect the different componets together. These can sometimes work loose. An impact can vibrate them just enough to cause the problem. It could also be the lens mechanism. Sand and grit can work into the gears and bind them up. If it zooms in and out smoothly then this maynot be the problem. If you hear any change in the speed of the motor when its zoomed in and out that could be it.
May 06, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
16 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
