Question about Gaggia Titanium Espresso Machine
Leaks water from side
I tried to brew a coffee with my new machine after assembly. It leaks water like crazy from the side. Anyone know what is wrong? Very annoying.
  • ck2usa Feb 02, 2009
    I have the water leaking problem. After making coffee or frothing milk. I got a puddle beneath the machine on the countertop.
  • Gaggia Expert
  • 109 Answers
Which side is the water leaking from?
Posted on Jan 31, 2008
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Miele cva 615 water leak
I assume youyr talking about a leak inside the machine and not at front or behind front door. Assuming this I would suggest drying the iside of machine, re-assemblig all covers (to ensure machien is safely earthed) and then make one coffee. Thsi diconnect from mains, open cover and chck where water has come from. It may be that the seatc for the o-rings has a scale build up ad this prevents even new o-rings from selaing properly. regards
I assume you're talking about a leak inside the machine and not at front or behind front door. Assuming this I would suggest drying the inside of machine, re-assemble all covers (to ensure machine is safely earthed) and then make one coffee. Then disconnect from mains, open cover and check where water has come from. It may be that the seat for the o-rings has a scale build up and this prevents even new o-rings from sealing properly. regards
Apr 07, 2014 | Miele Coffee System
Water leaks from the top of the right side of commercial coffee maker
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
My Espresso Machine leaks out the bottom
thier is a puddle of water that leaks out of the bottom of machine after i brew my expresso
Dec 29, 2012 | Mr. Coffee ECMP40 Espresso Machine
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Leaks water when brewing from right side where
It is possible that the small gasket under the water pan is damaged and needs to be replaced.
Jun 16, 2009 | Bunn VPR Coffee Maker
Frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Feb 23, 2009 | Saeco Odea Giro Plus Coffee Maker
Leaks water from left side of machine
you have to open the machine it probably the pump that need a seal kit to make sure you have to open the cover activate the machine and lock what leaking they is no miracle cure for our trouble you got to get dirty good luck cheers
Jan 30, 2008 | Saeco Vienna De Luxe Espresso Machine
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
215 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
