Question about Whirlpool Washing Machines
The water runs in the tub while it is filling but
The water comes into the tub but it flows start out. the tub doesn't fill up! I am in Zambia for another week - would like to see if I can fix it before I return to the states
  • Whirlpool Master
  • 3,463 Answers
Try lifting the drain outlet hose higher, as it sounds like it is syphoning due to the hose being too low.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
Water level switch on kenmore 500 washer
Probably a defective fill valve or level switch but could be a controller fault
May 31, 2018 | Kenmore Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Water flows constantly during the spin cycle
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
Dec 08, 2011 | GE WBVH6240F Front Load Washer
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Flahes from FL to the temperature (13) after refiling. Temperature level will also not increase.
FL is usually a flow sensor/switch fault. If you have just filled the tub, the pump may not be properly primed. The best thing is to fill the tub through the skimmer when you first start filling it, that ensures the pump is filled with water and is not air locked. You may have to force water into the skimmer to push the air out of the line or loosen a union on the discharge side of the pump to get it primed. FL will not let heater run because it thinks that there is no flow.
Nov 18, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
The water won't shut off in my Neptune
davedun: Take a look at the [water load or water level] switch from the inside & u may see a rubber tube coming out and going to the bottom of the washer tub.The rubber tube should be connected to a VACUUM switch.This switch works by pressure from the weight of the tub when it is being filled up with water.When u set the water level switch on a "lite load" ,as the tub is being filled the diaphragm is pushed down causing a vacuum to pull down another switch which causes the water to stop, causing your machine to start washing, rinsing, etc. This vacuum switch could be of many configurations\shapes\sizes & will almost always be at the bottom of the tub to measure the weight of water going in.
The key is a rubber (clear-see through, or black) coming from the top of the control panel going to the switch.
2nd. electronics sensors on the side of the inner tub ( that catches the water ) to measure water weight. Hard to find, because they could look like anything. Even I have trouble finding them!!
P.S. TURN THE POWER OFF AND UNPLUG !!!!
P.S.S. get back to me if u need some more help.
Jun 02, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Not enough water in tub
Mderford, on a normal fill, the water should be just above the filter screen. 1.8 gallons first fill, 1.7 on all other fills. Don't think it would be a siphoning problem as you are not having this on the pots/pans. Check the float, make sure it is not sticking. You can check the inlet valve filter screen to see if it is not plugged. Run it through the diagnostics cycle by pushing high temp-air dry-high temp-air dry. Some models it's heated dry-normal-heated dry-normal. It will run through a self test for about 20 minutes. See if any error codes come up. Fill time should be approx. 1:30 to 1:40 seconds. If any of the aformentioned doesn't turn up any results, then it's possibly a faulty fill valve drive circuit on the control itself...Catriver..post back.
Oct 02, 2006 | Whirlpool 24 in. DU900PCD Built-in...
Washing Machines Logo
19 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
