Question about Welding Tools
I have a century 80 gasless wirefeed welder model 117-071-000 i need a drive moter gear box assy how can i get a dealer near my town pennsburg or a phone number to call them for the parts thank you edward
  • 251 Answers
Century has now been bought over by lincoln welding
this link is for dealers in your area
http://www.lincolnelectric.com/products/service/locator.asp?transaction=search&template=map_search&maxSearchResults=5&radius=999&search1=0&search2=1&city=pennsburg&stateProvince=&postalCode=&country=US
this is a link to the parts diagram
http://content.lincolnelectric.com/pdfs/products/navigator/parts/ P531.pdf- 506.4KB
if this helps please vote
Posted on Nov 12, 2009
  • 3,600 Answers
This site has the parts list that you will need you may have to buy the hole head assembly though. I had one of these and it had the same problem cost me 150 bucks to fix. http://www.sjdiscounttools.com/shop-tools-equipment---supplies-welding-equipment---supplies-mig-welders.html
Need manual for Century 70 wire welder
Without having the model number (it starts with 117-***) I can't send the proper link, but here's the link to the Century 80 just a newer model but almost the same as the 70:
http://www.lincolnelectric.com/assets/ServiceNavigator/Century/Century/IM888.pdf
Hope it works for you. Have a great day.
Nov 27, 2011 | Welding Tools
Wire feed speed was surging & now the motor just clicks & turns about 1 degree on the rollers. I suspect it may be the relay for the drive motors. Any help with this problem is...
To test your theory you'd need to check the voltage going to wirefeed motor with a multimeter set to DC voltage. This is dangerous as you'd need to have the covers off the machine. If the motor was getting voltage the whole time you pressed the trigger the fault would lie in your wire feed motor gear box. If it is a small mig welder, i would think from the sounds of your fault that it is the gear box that you're having trouble with. To find a replacement you'd need to write down the model number of the mig welder and order a replacement part through a repair shop.
Jun 07, 2011 | Pro Line Welding Tools
Need a new torch assy for my clarke 130.
Go to your nearest Praxair store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at all welding stores.
Dec 02, 2010 | Clarke Power Products Clarke 130EN...
On a Century 130 Mig Welder having trouble getting any penatration with gasless fluxcore wire. any suggestions?
Check to see if you have the polarity corect for innershielded wire the gun should be negative and the ground should be posative. also check your heat setting and match it to the guide lines on the cover door.
Sep 21, 2010 | Welding Tools
Can I convert my Cebora Stag 196 welder from gas to gasless
Most gas welders double as gasless welders. Just buy the flux core wire and use it without the gas on.
Jul 07, 2010 | Welding Tools
I have a century powermate 70 mig welder and using .30 fluxcore wire. the machine says that it is gasless also. the machine will not weld right. is this the right wire or what could be wrong?
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Jun 29, 2010 | Welding Tools
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Jun 27, 2010 | Century 80GS Flux - Cored Wire Feed Welder
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Nov 19, 2008 | Welding Tools
Welding Tools Logo
1,227 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
