Question about LG 50PC1DRA 50 in. Plasma Television
When i press the power button on my tv it immediatly cuts back off
    Habit-Forming:
  • 41 Answers
Defective power board. Three options.
1. Replace defective capacitor on pwr board.
2. Replace complete board( google part # 6709900020A) 180.00
3. Call local service man.
Posted on Dec 18, 2009
  • karikuffnerk Jan 07, 2011
    is there any sautering (sp?) involved in replacing the board? Or any additional tools required for the install?
    Thank you!!!!!
Model number p46151wk, can turn tv on with power button but automatically turns back off
A number of possible answers---I need to know two things= on back of set aside from model number is there a chassis number like PTK 195 etc? Is power light green and going off or remains on?
Aug 27, 2012 | RCA P46924 46" Rear Projection Television
When i turn tv on it immediatly shuts back off
If model number begins with WS or VS (on back of set) when it shuts off press and hold both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know model number and what error code you find.
If this was helpful, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 17, 2010 | Mitsubishi Televison & Video
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
I turn on my tv and it immediatly shuts off
I have a big box flat screen tv that after you cut it on it cuts back off and then you cannot cut it back on
Sep 22, 2009 | Samsung PCL545R 54" Rear Projection...
Unable to program my Time Warner Cable remote to Symphonic TV
the instructions are on the back of the remote. if lost. you have to:
1) Turn tv on ( i would suggest turning it off then on)
2) Press the Device you want to sync (tv)
3) Press and hold the setup button it will blink once...let it blink twice before you go to the next step.
4) press 9-9-1
5) press the power key on the remote
6) press the channel up (CH +) button repeatedly until the device (tv) turns off.
7) when it cuts off immedieately press the setup button.
Mar 14, 2009 | Symphonic WF20D4 TV
HDMI connection not working
I have a DCT6416 which is essentially the same unit but with a bigger hardrive. I just had the same problem and was able to fix it.
First connect your DVR to your TV with the composite RGB cables and disconnect the HDMI. Then power your unit on. Then power it off (using the power on the DVR not a remote) and immediatly press the menu button on the DVR (not the remote). A white screen with black writing will come up. Using the down arrow buttons on your DVR go to the bottom line where it says "reset factory default" Toggle down to that and then use the right arrow key and your settings will be reset. Then exit out of that by powering off. Now remove your composite cables and replace the HDMI. You should be back up and running.
Feb 06, 2009 | Arris DCT6200 DTV Receiver
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Code for the one forall for a sharp tv
You do not need a code...
Heres how to set up your remete..
Turn on the devise you want to set up.
Press the set up key on the control firmly until the red light lites up and stays lit. Now press the key for the devise you are trying to set up(dvd, vcr, tv etc..).. the red light will now turn off.
Now facing the devise, begin pressing the power button several times until the devise turns off. Be careful not to press the power button any more after it turns off. After it turns off , you must immediatly press the enter key in order for the control to save the code. Now your control is set up. If this does not work , it is because you pressed the power button once more after the tv turned off....
This process might take you anywhere from 3 to 5 minutes.
despino1@hotmail.com
Jan 10, 2008 | Sharp 27C-240 27" TV
LG 50PC1DRA 50 in. Plasma Television Logo
781 people viewed this question
Computer Repairing
Computer Repairing
