Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
DOES THE THIS FRIDGE MODEL #106.74912401 REQUIRE TO REPLACE WATER FILTER FOR FRONT DOOR WATER DISPENSE?? ITS A KENMORE ELITE
  • 6,784 Answers
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Posted on Nov 12, 2009
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Oct 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
