Question about RCA Universal Remote Control
Rca tv and rca remote
With the remote i cant change the channel to get the tv to switch to play a dvd
  • Anonymous Mar 22, 2014
    TV only plays one station remote or switch on TV will not change it have changed batterries
    Novelist:
    Champion:
  • 211 Answers
Is the remote control the one that came with the set or is it a universal? If the remote came with the tv, it may have a bad internal rubber pad board ( not fixable ), if it's a universal remote, you may need to change the code of add the codes for the dvd. The dvd and the tv work internally on seperate codes. I hope this has helped
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 26, 2008
Cant find auxillary channel
You will need a connection to an aux,a VCR, DVD etc. The TV will recognize and display. You may need an original RCA TV remote with an aux button. RCA universal remotes will also sometimes have this. Or in this case press your remote button to 00. Sometimes this will work, or press channel search while playing an aux device, Thanks for listening, Sincerely, Matt.
Feb 28, 2013 | GE 35GT695 TV
How can i hook up an external dvd player to this tv? i followed the dvd player instructions but i cant get it to play...i can only hear the sound
On the front you have a yellow white and red port. Use the RCA cables from your DVD player to the front of this T.V. Change the T.V. input probably with the remote or just the channel buttons. If this doesn't work, use different RCA cables because the one's you're using may be bad.
Jun 17, 2011 | Sylvania 6520FDE 20 in. TV/DVD Combo
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Unable to get remote to switch to tv/video RCA remote tv is sanyo
It took me forever to figure it out. Press the input key, just below the 9. The TV channel should be on 3. Make sure you put your DVD in and press play manually, so you can see that it is on.
Hope that helps
Apr 03, 2009 | RCA 3-Device Universal Remote with...
RCA Colortrak Stereo Monitor won't play DVD/Nintendo
The way you describe having your TV/DVD connected you wont see the picture in the regular channel line-up.
You will have to tell the TV to to switch to the video input. This is usually done by navigating the menu to the "input" and selecting video 1, video 2 etc
Failing that try changing to channel 00 ( just type 00 in remote)
Some sets will allow you to type in 02 and then hit the channel down button on the remote.
If you have the user manual it will give you the exact steps you need to take.
Mar 13, 2009 | RCA F26317 TV
Cant see dvds on my emerson tv
Hello.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
Feb 13, 2009 | Emerson EWF2704 TV
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
Televison & Video Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
