Question about Kenmore 62602 Electric Dryer
I have a kenmore dryer that I am trying to replace the motor in and I having problems removing the old motor
  • Curtis Sewell
    Curtis Sewell May 11, 2010
    You need to describe further your problem removing the motor...do you already have the dryer disassembled and cannot remove the motor or do you need help disassembling the dryer to get to the motor. Please clarify your request
  • Kenmore Master
  • 2,128 Answers
There should be two screws holding the motor in,and one in where the blower wheel housing connects to the exhaust pipe,pull the blower wheel housing to you until it separates from the exhaust pipe and then slide the motor to the right,it fits into the frame,also if you are having problems whit the clips just get a screw driver,stick it in the clip and push down or even easier hit the screw driver down and the clip will pop off,there are holes in the clips and a metal holder that is on a 45 degree angle and the clip has to be pushed down just on one side low enough to remove it,then just slide the other side off,remember how it comes out,the motor spins and locks in so just take a mental note where the harness plugs onto the motor and the angle the harness is in before you remove it,hope this helps.next time send model number
Posted on Nov 12, 2009
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Kenmore 500 series dryer won't start. Only 2.5 years old.
turn the drum with your hand,if it feels hard to move you could have something stuck in the blower wheel that is below the lint filter and behind the duct that the filter slides into or the belt could be jammed,if it moves try starting it it might start you could have a flat spot on the motor and most likely you'll need to replace it,if it'shumming it's the motor making the sound
Feb 14, 2010 | Kenmore Dryers
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Need to know how to remove the motor on a Series 80 elec dryer.
The motor should be removable from the back and will require removal of the back panel. The bearings on these motors are brass "bushing" type, not ball bearing. You may have some success oiling them with a straight weight oil like 30w, but it may not last too long. Once the bushings start to go, it's usually time to replace the motor. You should be able to get another motor for the unit from Sears Parts Direct. I applaud your efforts!
Mar 28, 2009 | Kenmore Dryers
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Kenmore dryer not spinning---how do i disassemble to see if belt or motor is bad?
kenmore dryers are the easiest dryers to work on. unplug! remove 2 screws @lint screen top. insert screrwdriver under top @ each end and pop top up. disconect wires to door panel. remove 2 5/16 screws at each end inside. lift front door panel up and out.( the bottom of the panel is held by spring clips. replace belt if broke. remove drum if not and check rollers. note: belt route at idler pulley.
Jul 19, 2008 | Kenmore 75944 Gas Dryer
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Kenmore 62602 Electric Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
