Question about Maytag Atlantis MDE7400AY Electric Dryer
Electric two year old dryer not producing heat. Looking for possible causes. Thanks
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Nov 12, 2009
Testimonial: "Everything was tested. All components work. What appeared to be a 240 outlet was only half wired, delivering only half the juice need for heat.Tnk"
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
The dryer will not produce hot air...I was looking for help in locating the heating element so I can see about replacing it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.'
Aug 08, 2011 | Kenmore 659 Electric Dryer
Our dryer has no heat. The drum turns and we checked the vents. All clean. Also we checked the fuse. Is there a heating device? It's 5 years old. Thanks Cathy
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 23, 2010 | Whirlpool LEB6300 Electric Dryer
Not getting any heat on any setting. My Neptune dryer is now 6 years old. Is it possible a fuse has blown? Thank you.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Dryer suddenly does not produce hot air
have the exact same problem, just over 1 year old no heat! first off my duct work under my floor is like a snake and is not a straight shot out of the house. I beleive this caused a ristriction in the venting because dyer seemed to be running hotter them normal. I took the top off the dryer and pulled the vent tube out of the bottom of the dryer. To my surprise found a three inch layer of lint on the bottom of the machine and also on the heating coil. After cleaning out all the lint i took a volt meter to the two wires that come down to the heater. started the dryer and found i had 220volts at the heater indicating the heater is out, found one on ebay for about 50 bucks. will be installing this weekend and will let you know how it works.
Mar 08, 2010 | Samsung DV218AEW Electric Dryer
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
Gas Dryer won't produce heat
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
It should only cost you about $90 to repair if a technician comes out to fix a fuse.
I wouldn't try to repair it unless you have some knowledge of electrics. If your dryer is less than 12 years old, I would recommend you fix it. Hope this helps.
Best of luck :)
Aug 25, 2009 | Whirlpool Dryers
No heat from tumble dryer
Start checking the thermal fuse.
You need to have the heaitng element tested, that is the most common cause for no heating on electric dryers.
Check also if the fanb is working.
This seller has replacements and diagrams for most models, try entering model number
See also There's no heat
Jan 06, 2009 | Dryers
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
