Question about Air Tools & Compressors
I AM GETTING OIL IN THE AIR - Air Tools & Compressors
  • geoman84 May 11, 2010
    What kind of compressor do you have?
  • 2,176 Answers
Could be cracked piston rings bad gaskets too much oil in the crankcase, wrong viscosity oil in other words quite a few things. what was done to the compressor last and start from there. Check the simplest things first and then work backwards.
Posted on Nov 21, 2009
All the engine oil is getting pumped into the air cleaner. The break power booster needs replacing and I'm wondering if this can be a factor due to vacum?
Oil getting in the breather assembly is from blow by. Is the pcv valve working? If so I would suspect a high mileage engine and not much can be done other than rebuild
Apr 14, 2015 | 1985 GMC C2500
Whats the benifit of an oil less air compressor
Oil free compressors are used when oil could contaminate food products, or maybe spraying where oil down the line would ruin a spray job, although adequate filtration to stop the oil getting to point of use
Aug 30, 2014 | Air Tools & Compressors
Oil blowing into air filter on 89 jeep Cherokee
If you are getting Oil in your air filter it is most likely due to the PCV Valves on the Valve cover going bad it happens a lot. the one in the rear on the Valve cover goes bad and causes it to suck oil into the filter box. replace vacume lines while your at it as they are most likely getting old to
Dec 01, 2012 | 1989 Jeep Cherokee
2003 sunfire using oil - oil in air box by throttle body - where is pcv valve located
Check and or replace your PCV valve. also make sure the oil level is not overfilled.and your airfilter is not dirty/plugged
Aug 26, 2012 | Pontiac Sunfire Cars & Trucks
Oil is getting in air cleaner what to do
thats shows your car engine is worn out. or first change your engine oil and drive for a while like two days test, when the problem is not solved then your car Piston Rings are worn out..especial the Oil rings which passes the slite oil through the compression rings up to the combansion chamber till comes through the breather ending to the Air cleaner. but i would recomend u to change the oil first before getting deeper. all the best.
Aug 27, 2011 | 1999 Jeep Grand Cherokee
Bike was running great then it started to studdering.brought it home looked at then noticed that the air box was full of gas and oil. why?
Some compression from the engine is getting past the rings and into the gearbox. With the compression comes some unburned fuel. The fuel mixes with the gearbox oil and increases the oil level in the gearbox. Now the "oil-gas" level is very close to the vent hose on the top of the gearbox. Remember that compression going into the gearbox? It now carries bits of oil-gas into the vent hose. Where does the vent hose vent to? The air box. The "low cost-getting by" remedy is to do an oil change, clean the air box, install a clean air filter and then do more frequent oil changes in the future. The proper fix is to do an expensive top end job on the engine. Please rate my answer. Thanks.
Jun 03, 2011 | 2004 kawasaki ZRX 1200 R
I took my 1981 Yamaha Xj650 for a first ride today. Revved her out on a straight and discovered that I left a 1km long oil trail on the road! After a closer inspection a lot of oil has worked its way up...
Air getting in BEFORE the carb is unfiltered and can harm the engine. Air getting in from BETWEEN the carb and the head is also unfiltered but more importantly leans the fuel/air mixture causing the engine to run hot and sometimes causes the idle to climb by itself. Compression is getting past the piston rings, (blowby), and into the gearbox. The fuel/air mix getting into the gearbox, mixes with the gearbox oil diluting it, and some of the oil follows the pressure through the crankcase vent hose and into the airbox. Chances are that raw gas went from the tank and into the gearbox over the winter. This raises the oil level in the case and promotes the oil going into the gearbox. Just do an oil change and be sure to turn off the fuel valve at the tank when not riding. Please rate my answer.
May 10, 2011 | 1981 Yamaha XJ 650
Oil system manual for a 1987 softail (evolution). oil leaking from breather of engine system.
On your '87 Softail, the engine breather vent is behind and below the oil pump. The air from the breather is routed into the engine air filter by a metal pipe and rubber tubing that runs from the breather vent to the air filter. It is common to get a bit of oil in the air filter because of this system. The system was designed to meet EPA regulations of the time. Since then, the breather system has been modified to allow the engine to breathe at the top of the heads instead of down low on the engine. This resolves some of the problem with oil getting into the air filter but it still does not eliminate it. The only way to eliminate the oil from getting into the air filter is to reroute the air from the crankcase breather vent to somewhere else. Most people just let it exhaust underneath the bike by putting a small breather filter on the end of a short piece of rubber hose connected to the breather vent.
Good Luck
Steve
Apr 01, 2011 | Harley Davidson FXST Softail Standard...
1998 Ford Windstar 3.8L ScanTool says that Bank 1 is lean
if your getting oil in the air filter area, you have a leaking intake gasket or a leaking head gasket, run a compression test on it,
if the compression is where it should be on all cylinders then its a leaking intake gasket!!!
Mar 04, 2010 | 1998 Ford Windstar
Husqvarna 136 is not getting enough oil. Changed the pump, but it is not drawing it up to the bar
what you can do is try taking the cap off of oil tank drain oil, take chain & bar off try taking compreesed air or air blow nosel in hole going to blow & if its clogged it should blow out of cap hole or there might be a hole in line but it might have saw dust in oil clogging oil from coming out
May 22, 2009 | Heavy Machinery
Air Tools & Compressors Logo
47 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
