Question about Sony PlayStation Portable (PSP) Console
Problem w/ iso folder?
I put a game in my iso folder then the game start but when i turn off then turn it on it reads there's no game but when i open the iso folder the game is still there what seems to be the problem? i tried to reformat my memory stick and system setting to default still the same problem...can you help? tnxs!!
    Guru:
  • 352 Answers
If you have not converted to a custom firmware, then you will not be able to play iso files. check out pspmod.com, and qj.net for more info about custom firmwares and how to do it.
Posted on Nov 16, 2009
How to put games to my psp.
First, download the emulater for the type of rom (Game) you have. then download the Kxploit tool(get them both at PSP-hacks.com) unzip the emulator and start up the Kxploit tool, it will ask for the file name in the first column, just give it any name. then it will ask for the EBOOT.PBP file directory. tell the proggy where the EBOOT>PBP file is(where you unzipped it) then it will ask where is you PSP (connect your PSP via USB and go to my computer and see what drive letter says the psp) then go back to the Kxploit and select the letter. then click Generate and then you will get a pop up window telling you it worked. now go to my computer and go to X/PSP/GAME/EMULATOR U CHOSE, then place the rom(s) next to the EBOOT>PBP file and your all set, just ignore the SECOND EMULATOR U CHOSE%, and if you find a curropted data when running the emu, ignore it DO NOT DELETE IT>
hope that helps-solargame
or try this...
how to transfer a downloaded game to s psp from pc...
sometimes when we download games from internet, how can we put the downloaded games to PSP on PC? (Note: You must have a hacked PSP to do this.)
1.Connect your hacked PSP to your computer with a USB cable.
2.Turn on the PSP.
3.After detecting your PSP as a hard disk, open the disk to read your memory stick. Find the "ISO" folder in it (any hacked PSP has a ISO folder at the root of the memory stick).If not make a new folder named ISO.
4.
Put the game with postfix .ISO or .CSO on the "ISO" folder. (If you download a rar file or zip file, you should extract the file then select the ISO or CSO file.)
5.Disconnect the PSP and PC(click on safely remove hardware before disconnecting for safety). Turn Off the PSP completely. Turn the PSP back on holding down the R key. On the Red menu, go to Configuration and change UMD mode to M33 Driver - NO UMD. Click Back and Exit the Red Menu. You can now run the game without a UMD in the back. Find the game and try to run it on PSP.
6.If you can't open the game, make sure you put the right file on the right folder
simple tips...
  • You can also put movies from dvd to psp with the same way, but don't forget put the movie to the "Video" folder. The same goes for music.
  • Look for games to download online such as off of PSPshare or other websites.
Things You'll Need
  • PSP
  • USB Cable
  • Computer
  • Enough memory required for the game
if you think that this help you please rate me..
Jun 05, 2011 | Sony PlayStation Portable Slim Pink...
How to download in psp games
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Sony PlayStation Portable (PSP) Slim...
I put a game in my iso folder at first you can play the game but when you turn on the power it read there's no game but when i open my iso folder the game is still there what seems to be the problem? i...
well you have to check first in which format teh game is,
psp accpets *iso and *cso formats
the game should be in this format for it to work
if it is in this format then the game iso mite be corrupt, OR
U NEED TO MOD (CRACK) FIRMWARE OF UR PSP TO A MANUAL ONE FOR THE GAME TO WORK.
Nov 12, 2009 | Sony PlayStation Portable (PSP) Console
Can not play CSO, ISO games in firmware 5.5
You need fastloader...
Your folder setting for FASTLOADER should be like this.
Root directory:
+PSP
| +GAME
| +FASTOLADER
| +FASTLOADER%
+ISO <-- PUT YOUR ISOS THERE
+ISOMISK
+ISOSPLIT
the folder settings for UMDEMULATOR V0.8c are like this:
Root directory:
+PSP
| +GAMES
| +UMDEMULATOR
| +UMDEMULATOR%
+UMDEMULATOR
+ISO <-- Put isos here
Aug 30, 2009 | Sony PlayStation Portable (PSP) Console
When i update my psp 3.90 m33 to 5.00 my psp cant read iso or cso
reformatting erases all data and if you need an iso folder just create a new folder in the root folder
Aug 16, 2009 | Sony PlayStation Portable (PSP) Console
No games in my memory stick
If you are using a modded PSP and it sounds like you are, you need to make sure that you are putting your CSO's/ISO's into a foulder labled ISO.  To do this if you haven't already is as soon as you hook the PSP to the computer on the main screen with all the folders you need to create a new folder and lable it ISO.  You then place all the ISO's / CSO's in to this folder.  After you have done this unplug the PSP from the computer and go to the game tab.  At the bottom is a tab that says memory stick you will then click on that and you will see all of your games if not it does not hurt to mod it again.
May 28, 2009 | Sony PlayStation Portable (PSP) Console
Cant find my games
make sure you put the psp games cso files like Starwars.cso in the iso folder on ur card. other emulaotrs need to be in the psp/game.
So open ur psp find them .cso file[game] and the cut paste it to the ISO folder k
emulators need to be in PSP/GAME and maks sure ther emu isnt in a folder cause in cant read into two folders
o and if it doesnt work make sure ur VSH menu has the iso mount to sony np3076078
May 26, 2009 | Sony FORMULA ONE 2000
Psp
well...
once you have the iso file..
plug the usb cord to ur psp...
then. go to USB conection..
after that..
let ur pc read it...
then open the ISO folder after ur PSP is in USB Mode..
then..copy the file from ur PC..
and paste it on the ISO folder..
PS...ISO and CSO are accepted...
Dec 26, 2008 | Sony PlayStation Portable (PSP) Slim...
I cant play games on my psp v5.01 in its memery stick
IF YOU WANT TO THE OLD VERSION BACK AND PLAY AGAIN...... HOLD THE SWITCH UPWARD AT THE SAME TIME HOLD THE L AND R BUTTON AFTER THAT THE M33 RECOVERY MENU APPEAR... IF YOU HAVE SOME QUESTION JUST EMAIL AT SPONG3BOB11@YAHOO.COM
Dec 03, 2008 | Sony PlayStation Portable (PSP) Slim...
Corrupted!!
Try getting the game from another source and install it again.
Feb 07, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
35 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
