Question about Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Comp trips at cut off point so i have to reset each time
  • 89 Answers
The starting capacitor for the electric motor is probably at fault
Posted on Nov 12, 2009
What caused my bosch matter saw to quit cutting in middle of the cut
Several possibles:
1) Load exceeded circuit amps. Breaker tripped.
2) Load exceeded saw amps. Reset tripped.
3) Wiring failure in saw.
4) Wiring failure in supply.
Time to start checking.
Note- if the blade is dull or the load on the saw is too great it will trip one of the breakers.
Mar 26, 2016 | Bosch Saws
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
I have a Bosch Powerstar AE125 where the left cut-out trips. This problem began at the end of last winter to the point I was resetting multiple times a week. During the entire summer I might have had to...
I suppose I would ascertain that the supply voltage is the same there as the outer cutout connectors. If equal, the breaker can be faulty. Worse case the heater has an intermittent short causing overload to trip out.
Fix It!
Nov 02, 2011 | Bosch PowerStar AE125 AE125 Whole House...
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
Hi there, My compressor unit outside runs constantly. The fan inside will not come on unless the on/off switch on the thermostat is switched on and off several times. I have replaced the thermostat and the...
The compressor will keep operating tell reaches the temperature that been set for, also the comp. needs cut off to stop working, so you have the cut off & thermostat that controls the comp. you replaced the thermostat that leave you with the cut off…please make sure that you clean the unit before you re-hang the unit.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Sep 29, 2009 | Whirlpool ACQ122XK Air Conditioner
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Mar 31, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor Logo
89 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
