Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
I have PVCLE266M-L V3.0 and i disconneted all the wires and now im not able to on it coz i dont remember how the wiring of the power was
  • 54 Answers
Try looking at this pdf file page 17. This gives you the diagram on where to put the wires.
Link
Posted on Nov 12, 2009
Www emachines com support
try changing that power switch with restart switch SETS, i do that coz i dont really use restart switch. or check computer store, i recommended accessories or repair store.
ask for set of power switch cable. usually they does have it on sale.
HOPE SOLVE..
Oct 26, 2013 | E-Machines Computers & Internet
The food does not heat up. You can hear the fan on, and the bottom plate spins, but the food comes out ice cold.
in 99 % of cases the problem is the magnatron it is a very expensive part and unless the microwave is well worth the money we normally write the units off
sorry (
but i hope this helps
best of wishes
please remember to take the time to rank this reply .
Dec 02, 2010 | GE JVM1650 1000 Watts Microwave Oven
I just replaced my factory stereo in my 2002 honda accord. i have two red wires left over that appear to be my dash lights. i dont know where to connect these two wires to make the dash lights come on when...
I have no idea about the wire that puts out gear position lights. But the one that makes dash be on constantly, is the memory wire for radio. You do need continuous power for radio to remember stored radio stations, audio adjustments and last source selected. Most aftermarket radios have two power cables, red and yellow, one is switched, meaning that it only gets power when vehicle is turned on, and the other one gets electricity constantly.
Oct 09, 2010 | 2002 Honda Accord
I have a 05 suzuki sv650 .. im trying to hook up some LEDs in the front and dont want to go all the way in the back with the wiring for power and ground. so i was going to splice into the turn signals jus...
Im not sure if you are UK based, but remember the turn signals flash, their power supply will receive an on/off supply from the indicator relay.
You do have your ignition up front, so you could trace a switched feed from your ignition switch (i.e. 12volts is found when you switch on).
For the earth return, you can use any ground wire (even the indicator one) in the 'area'.
LEDs draw very little current, so it is unlikely you will overload any circuit.
Aug 27, 2010 | 2005 Suzuki SV 650 S
I have a kenwood KMR-700U. We have disconnected all the speaker wires and only have power going to it. We have ereset it multiple times, but it will not come off protect mode.
try and taking power away from it completely just disconet the power wire and then hook it back up if that dont work disconnet the power and ground and maybe find a new better place for your ground
May 22, 2010 | Car Audio & Video
The color of the wires from my old and new radio dont match up!?
Jags are definitely a pure breed. The new radio most likely has writing on the wires that tell where they are to be connected to. I take that back. I just checked the wiring of an older model JVC unit and there or not listings. If your radios doesn't have writing just remember Orange(or yellow) is illumination, and it goes to the fuse block; red is power, going to the fuse block; the big black one is the ant.; the little one is the ground to the chassis. The others are speakers. Connect them to the colors they are closely resembling in your Jag. Connect the power and turn on your radio. You can reconnect the lines to the correct speaker by checking each speaker. hope this helps.
Jul 27, 2009 | 1990 Jaguar XJ6
No dash lights or dimmer control after installing a stereo system
you have to run a jump wire to you cluster when you pull the factory unit out the aftermarket units are wired just a little different find your illumination wire should be orange and make sure it is wired correctly you may have to tie it in to a different wire,,,, i did this on several gm trucks i cant remember which wire i had to jump it to but i belive i tied the amp and illumantion wires together and made it work your fuse will protect you from doing any damage if you should jump the wrong wire...
Jan 10, 2009 | 2000 Chevrolet S-10
Spark igniter doesn't arc
hi im gerbee fr.phil, much better to replace the part(igniter wire) coz that part cannot be repairable dont try to repair coz more dificult problem if u repair.to replace the part dismantle the unit or remove all the screw at the top of ur cooktop.before that unplug the unit fot ur safety.buy the part from the brand u carry.tnx i hope i help u
Nov 30, 2008 | Jenn-Air JGC8430 Gas Cooktop
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
