Question about LG WM-2277HW Front Load Washer
Machine is located upstairs in laudry room on a tile floor. During the spin cycle it sounds like it is going to come through the wall. Didn't I hear that LG was trying to correct the problem by putting cement in the bottom of units or something like that? My washer is located on a pedestal.
You need to balance the adjustable feet
Posted on Nov 12, 2009
Just moved our washer across country. Now the washing machine is bouncing all over the room during spin cycle. The machine is level. Does it have weights inside that can be adjusted?
yes and no, yes has weights, no can not be adjusted. inspecth the washer for any bent-dents in cabinet and under machine, legs etc. check floor for uneven tiles. last, is possible that internal damage has occurs during transport or a spring came loose in transit. to verify that you have to open iside and inspect.
good luck to you.
Feb 08, 2011 | Frigidaire GLTF2940ES Front Load Washer
Perfect level sounds very strange
Check the leveling feet on your machine. With the machine turned off, and with a small carpenter's level, check to make sure the machine is level front to back and side to side. Then give the machine a shake in each direction to make sure that the feet (which are adjustable). If the machine wobbles-even a little bit- adjust the feet until all 4 feet are in contact with the floor and the machine fails to wobble when pushed.
Rerun a load and see if the machine has stopped sending morse code...
you can also make sure that the fill hoses aren't banging into the machine or the wall during the cycle.
let me know if you have success!
Jun 01, 2010 | Washing Machines
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore he2t is very noisy due to the spin cycle. It shakes the whole upstairs
My HE2T was making a horrendous sound during the spin cycle. It was making a loud clacking sound and the machine was moving all over the place.
There are two things to check. The first is that the feet are on the floor and the machine is level. The second is a bit more complex. Remove the three screws that hold the lower panel. Underneath the drum on each of the four corners are suspension rods. One side is attached to the drum and the other side is bolted to the bottom of the washer. My bolts loosened up which allowed the suspension rods to clack back up and down as the drum spun. You'll need to tighten those bolts very tight and then give it another try.
Attached on the inside of that cover is the troubleshooting guide. There is a manual diagnostic mode and you can step it to the spin cycle so that you can test the spin balance without having to run through a full cycle. Make sure you have some clothes in there during the test.
Oct 25, 2009 | Kenmore Washing Machines
Kenmore elite steam front load washer
take the shipping materail out,,remoce the 4 bolts on back of machine,,the washer should of came with a little wrench...after removing shipping bolts put the 4 white sluggs or vcaps in hole ,,pull bolts with rubber or plastic grommet..onthejob
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise
sounds like there's something inside the tub, can you do a visual inspection and maybe run your fingers around the agitator..stranger things have happened.
Mar 04, 2008 | Frigidaire FLGB8200DS Top Load Stacked...
Lg Tromm wm2277hw
Try Ke shake away pads. i found them at lowes for $30. Solved my problem with a front load pedestal. Shook the pictures off the wall in the room next door. Best money I ever spent.
Jan 28, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
164 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
