Question about Philips HTS3410D/37 700W DVD Home Theater System System
Showing red image
I use ypbpr cables to connect to my lg plasma tv model ru-42px10 the picture on tv shows red.
  • 8,596 Answers
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Posted on Feb 18, 2008
6ya staff
SOURCE:
My LG plasma tv model 42PX4MVH the picture has gone all black but the sound is still there,
You burnt out the backlit lamp. unfortunately there is no easy fix for this. If still underwarranty great, if not... it will cost more to fix it then buy a new tv probably.
Mar 28, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have sound, but screen flickers and cant get picture, it sometimes shows a picture for a min then goes again, and off and on we get a red bar down left side
What you most likely need is this:
http://cgi.ebay.com/NEW-LG-Y-SUSTAIN-SUS-BOARD-RU-42PX10-RU-42PX10C-PLASMA-/400195756638?pt=LH_DefaultDomain_0&hash=item5d2d86a25e
There's a minor chance it may be something else, but with the sporadic problem appeareance it would be impossible to diagnose remotely.
This is the most likely reason for similar problems, but, I repeat, no guarantees.
I am not anyhow affiliated with whoever is selling this. You may be able to find better deals elsewhere.
Feb 18, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
The sound works but the picture don't show
Hi
This is more than likely your Y Sustain board that has failed.
Take the back of your tv and look to the left hand side, you will see a main board connected to 2 x buffer boards that connect to the screen via ribbons.
Take the part number of the main board and Google or Ebay for a replacement.
98% of the time this will cure your problem.
Hope this helps
Apr 09, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
Lost picture on my LG 42" plasma model number 42PC1DV
it is problem high voltage unite problem (EHT) change it then solve your problem
Sep 03, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have a 50" LG Plasma that has lost color only with the tv
the main total assy might be the problem. it controls color, pix size and such.
Jul 09, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Lousy picture
go into the menu and find the contrast: reduce the red part of the RGB until it is suitable
Jun 15, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Hello I have a LG 42inch plasma, RT-42PX10 that has no display at all but audio is working fine. Can you please help, I've opened the back of the TV but not sure what to do. Thanks
i had a similar problem with my lg tv i went to menu/options scroll down and did a factory reset it tunes your tv in again and after that my picture came back
Dec 19, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Feb 23, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
316 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
