Question about Acer Aspire 5500 5570-2609 Laptop
My laptop swicthes on briefly when the connected to the electric then switches off as if the battery is dead. but it does look like it is charging and wont switch on with the battery out pls help. the lights on the front one is flashing and one is a constant orange
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
Discount laptop battery,here you may get your answer.
Posted on Jan 11, 2010
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
Not charging
1. Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2. Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3. Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4. Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5. Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6. Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7. Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
I hope you find it very helpful.
Thank you. Please rate me.
Aug 10, 2011 | HP Pavilion dv6000z Notebook
I left my lap top in my cupboard while I was away for a month. The battery and the computer wer intact and the battery was very much o.k. After coming back and swicthing on my laptop the it was o.k. but...
kindly remove the battery when the laptop is off also remove the power chord ,then remove the battery an clean it with a brush properly ,then re fix the battery again then keep it for charging for three hours then see weather it work if not then its dead ,if u r replacing the battery the please buy the original batter so u will not be in risk in spoiling the laptop always use the original never go for the refurbished one glad to help you fixya team.
Dec 21, 2010 | Acer Computers & Internet
Ds red light flashes briefly
Is your DS old? If your battery is charged 500 times, it won't work anymore says Nintendo. Anyway, get it fixed by Nintendo!
Oct 09, 2009 | Nintendo DS Console
URGENT! My computer doesn't switch on and Ihave a tight schedule.
please try a different ac-adapter, since its most likely defective.
if the powerled just blinks 1 time it usually indicates that the battery is empty and need to be charged.
May 29, 2009 | Sony VAIO PCG-K35 Notebook
I have Nokia 1100, battery is dead & won't charge
I am sure if you take this to the nokia care they have an easy replacement for the battery.
Thanks
Fame !
Apr 27, 2009 | Nokia 1100
No Power
i had this problem to maybe a couple months ago, the problem is either your charger is dead. or the connection of your charging port has got moved around.and its not being charged anymore.
Dec 16, 2008 | Computers & Internet
My Mobile Nokia N70 is not swicthing on
Your battery may be dead or not charged.
First charge your battery & then switch it on.
Jul 28, 2008 | Nokia N70 Cellular Phone
Lap top is dead
Do you have tried remove the battery and plug in the power cable and try to turn on the laptop? That could be caused because of the battery.
Try it and tell us more.
Nov 15, 2007 | LG X-Note LM50 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
