Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Pilot light will not stay lit, have full tank of propane gas
  • 251 Answers
Clean or replace the flame sensor
this link is for the parts diagram
http://www.haywardnet.com/inground/products/replacement_parts.cfm
if this helps please vote
Posted on Nov 12, 2009
Pilot light lights but will not stay lit with full Propane tank.
Unscrew the thermocouple at the gas valve. Lightly sand the connections,seat and thermocouple end. Sometimes the tiny current generated that keeps a gas valve open will be diminished by corrosion. don-ohio
Jan 10, 2017 | Heating & Cooling
1972 atwood water heater
Check your propane tanks (are they full?), make sure the valve is on, then check to make sure gas is making its way to the hot water tank, if the pilot lights but won't stay lit your flame sensor is faulty.
May 14, 2014 | Water Heaters
My fathers Bosch water wizard tf 250 will not start. the water will flow but no gas will not ignite or come through the pipe to the heater. the gas bottle is full. thanks Dave Tooley
Dave, make sure that the gas valve on the Propane tank, is fully open and that the inline gas shutoff valve near the heater is turned ON. Those are the basic two things that would prevent the gas from flowing thru the gas line, to the heater.
If the above valves are ON, the problem then lies with the gas control valve on the water heater. If it has pilot light that has to be lit, make sure that the heater's gas control valve is properly in the PILOT Position, before attempting to light it. It must be able to be pushed ALL the way in and you should feel strong pressure pushing back at you (other than spring pressure). When you feel that, it's in the PILOT Position and ready to be lit. Once it's lit, continue to hold the Pilot Button in for 1 minute, then release it. If the Pilot stays lit, turn it to the ON Position.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 22, 2011 | Heating & Cooling
The heater is attached to the propane tank properly; however, when I try to light the heater, the push valve does not allow the gas to pass to the heater to be lit. I do have all of the valves open on the...
Typically there is a safety device directly above the pilot light that must be up to temp for the gas to flow. You did not specify if the pilot is lit. If not, hold the lighter at the pilot light while depressing the button for one minute. This allows the sensor to warm to operating temp, thus allowing gas flow. Once pilot is lit adjust the temperature accordingly.
Feb 19, 2011 | Heating & Cooling
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Pilot lite will not stay lit, have a full tank of propane
YOU WILL HAVE TO TAKE THE TUBE FROM THE CONTROLLER TO THE PILOT TIP APART AND CLEAN OUT THE ORFICE AS THE SPIDERS MAKE NESTS IN THEM.
Nov 12, 2009 | Hayward H Series Pool & Spa Heater 400k...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Kirkland outdoor heater will not stay lit
The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
May 31, 2009 | Stainless Patio Heaters - Steel Deluxe...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
160 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
