Question about Car Audio & Video
CAR AMP T4004
I WANT TO KNOW WHERE CAN I GET PARTS(46N15)
  • 631 Answers
If you're in the US, Mouser.com has the fqa46n15.
Posted on Jan 08, 2008
No spark
Why did you change the coils?
NO--- Parts--- get replaced in a wish & hope strategy
First--- you obtain the info on the part of the system your
about to work on or have trouble with
You spend hours or days on the internet before going to
the car
Then your prepared to know how to TEST components &
systems---------- to find a problem----------
It is all about finding a problem,the fix is a given & usually
easy, if a part tests bad or a wiring issue brings things back to life.
On the internet there is all sorts of info,video & such about your car,
your motor,your motors parts & systems & how to test them & you
can print that info & take to the car to do the testing
If you have no understanding of the basic mechanical engine
or ability to use a volt meter, then your off the a repair shop & they
don't do well sometimes either
When you come to a site like this, you have to provide the motor
your working on & lots of test results-- eg: what problems are you
having,not some shop that failed to help you,your issues,what you
want to know, how to do
All we can do is guess or point you in some direction
Mar 30, 2014 | Oldsmobile Calais Cars & Trucks
Car sitting for a year, turn over but won't start
CLEAN & DRY ALL PARTS CHECK FUEL IS GOOD,ONLY IF YOU KNOW WHAT YOU ARE DOING PLACCE SOME FUEL IN CARB ,CLEAN & CHECK PLUG GAPS,A CAR STANDING WILL LOOSE THE PETROL ORIGINAL STRRNGTH
Oct 04, 2012 | 1997 Buick LeSabre
I have 4 10 inch subs a t15004 amp a t4004 amp and a 40 farad capacitor and i need a wiring diagram of how to wire it because the people wired it wrong. it drains my battery completlet dead can u tell me...
Here is the link on how to wire subs
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Reason for your battery being drained is becuz your alternator isn't able to keep up with the power distributed to your amps becuz you are pushing way too much power. I would recommend a bigger alternator, separate batter for your cap and amps so your battery isn't drained.... Yes I understand that the cap is suppose to hold the power but your electrical system wasn't designed to take such a power loss due to running your stereo.
Sep 19, 2010 | Rockford Fosgate T15004 Car Audio...
I need parts for an amp
callem up im sure someone in tech dept. call help ya jus cus its not on a screen dosent mean rockford doesnt have it....i mean they made the amp n all .....u know
May 14, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Front control arm bushings from parts stores are not the same size remove from my car. existing length dim's are approximetely 3.0" & 2.5" and bushing O.D is approximetely 2.325" & 1.410" front...
try a different parts store ....not all behind the counter know what they are doing ......bring in old part with vin number ....good luck ...have had it happen to me too ..eventually i found the right place and parts ....
Jan 02, 2010 | 1998 Buick Park Avenue
Need parts
what kind of parts? if you need electronic components then go to digikey.com or ebay. but digikey has a great tech support.
good luck
Aug 10, 2009 | MA Audio M1900XE Car Amp
My brother needs to know what fuel pump & presure
195 - 200 liter per hour. The parts store should have the information on his type car. Fuel pressure should be 30 psi in order to start the car.
May 18, 2009 | BMW 525 Cars & Trucks
Soundstream ribcom500
Contact www.resolutionelectronics.com.au
they should be able to help and have all the spare parts.
Nov 07, 2007 | Soundstream VGA400.2 Car Audio Amplifier
Any suggestions to get this transistor?
Um, hard to find eh ? Ok here are 2 links for those parts, in stock at mouser. FQA 46N15: http://www.mouser.com/search/ProductDetail.aspx?R=FQA46N15virtualkey51210000virtualkey512-FQA46N15 FQA 36P15: http://www.mouser.com/search/ProductDetail.aspx?R=FQA36P15virtualkey51210000virtualkey512-FQA36P15 I didn't see any cross refs for that one. The only thing i didn't check was searching for other 150V N-Channel QFET, and 150V P-Channel QFET's, if you find some you could compare the datasheets. If you don't have time to lose, order from mouser :) Cya ! cheebster.
Jun 17, 2007 | Rockford Fosgate Punch P4002 Car Audio...
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
