Question about Apacer Memory Audio Players & Recorders
I would like to now what's the soft I must use for adjust and programming a radio Motorola GM 950.And where I can find it best regards Thierry Prunier
5 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: Volume programming
Not possible without disabling the speaker.
Posted on Jun 24, 2008
SOURCE: if any radio FM new soft
I want to use fm radio new soft for my motorazrar v3i
Posted on Feb 19, 2009
  • 24 Answers
SOURCE: Motorola GM 350 programming software
try this link
http://www.cqham.ru/sch_eng.html
Posted on Jul 14, 2009
  • 44 Answers
SOURCE: code bar print are shifted one of 3 are correct
To reset the printer to its factory default settings, hold down the FEED button until the error LED has completed its FOURTH set of flashes. You can the reset any changes that you had to make initially when first using the printer.
Posted on Dec 29, 2009
How to reset the program
The battery eliminator does not require programming. (This is the category the question was posted in.)
If you are referring to the radio, you will need to visit a Motorola dealer for programming. It requires software, cable and a RIB (radio interface box). The software is proprietary to Motorola and available by subscription to dealers and qualifying entities.
Best regards.
Apr 16, 2013 | Motorola GP300 Compatible 2 Way Radio...
I bought a Motorola HT1250 Radio off Ebay from japan and cant program it
You will likely need the same version or newer of the software used to originally program the radio. You might check with your local Motorola dealer to see if they have the most recent Radio Service Software (RSS) and give it a try. Or a nationwide repair facility for after-warranty radio repair might have some idea how to get it to program properly.
The software is proprietary to Motorola and only available by subscription to Motorola Solutions dealers and certain other user types.
Best regards.
Feb 26, 2013 | Motorola Ht1250 Vhf 136-174mhz 128 Channel...
Can i clone motorola xts 2500 radio to a motorola mtx 8250 ls radio
No, they will not clone. The radios are two separate models with two separate programming softwares. If the radios are the same bandsplit, they can be programmed to match one another using the appropriate softwares.
Best regards.
Feb 08, 2013 | Radio Communications
Narrowband or wideband
The answer to your question depends on the radio model. Some radios have the capability when being programmed to have wide- or narrowband designated by channel. An example would be current model Motorola business/commercial radios such as the CP200.
Radios produced in the early 2000s were sometimes manufacturered in just one type of channel spacing. In these radios the entire radio is either wideband or narrowband.
In radios produced prior to 2000, most all were wideband only.
Best regards.
Aug 24, 2012 | Motorola Walkie Talkie 2-Way Radio
What software is required to program a motorola cp125
Motorola programming software is proprietary to them, radio dealers must pay for a subscription to each software. You would need a programming cable, radio interface box (RIB), and RVN4196 software subscription. Your radio should be programmable at your local dealer for a reasonable fee.
best regards
May 22, 2012 | Motorola Radius Cp125, 4 Ch, W Chargers,...
Is there any frequency adjustment for a Motorola MU22CVS?
Sorry, but the answer is no. The radio is in need of repair. Typically around $69 (US).
Best regards.
Apr 01, 2010 | Motorola MV22CVS VHF (2 Channels) 2-Way...
How to retune a p210 i have 2 but they dont communicate with each other i need them to be on simplex and the same frequency thanks bruce
The P210 is a dealer programmable radio. It requires Motorola proprietary software, a RIB (radio interface box) and programming cable. The computer used to program the radio must be the same vintage as the radio. Newer computers are too fast for the processor in the P210. Most Motorola dealers would be able to assist you in programming and retuning the radio.
Best regards.
Nov 24, 2009 | Motorola Radio Communications
HT-1000 has low Tx audio and programmed PL doesn't
While there are some adjustments which can be made in the RSS, doing so would not necessarily solve your problem, as it may create another. These setting would require the radio to be adjusted by a service tech using a service monitor. Your PL problem may simply be a programming issue. Double check the PL setting in the radio, also check to see if it is to be inverted or standard PL. If your radio is Transmitting low to other units, you could also be mixing narrowband and wideband radios. If so, one will talk softly to the other, while the opposing radio will be very loud talking back (among other things). And one other simple thing to check when having Tx issues is the antenna. Be certain you are using the correct antenna, the antenna is free of dry cracks or damage; and the antenna is attached properly.
After checking all the above, if you do not solve the problem, contact your local dealer or service center.
Best regards.
Sep 19, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Volume programming
Jun 20, 2008 | Motorola Radio Communications
Top Apacer Memory Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
