Question about Epson TM-U220 Matrix Printer
Brand new printer will print one or two tickets, then flash a red error light. Turning the printer off and back on resets it, but only for 1 or 2 tickets.Replaced printer for the same reason.
  • Epson Master
  • 19,396 Answers
Hi.
Ensure that you are using Epson original rolls, and that the label format chosen in software settings is the same one as the one of the roll.
Either than that there is nothing else you can set on this simple printer.
Regards.
Posted on Nov 12, 2009
Have a problem with HL-5370DW Status LED is red &
Hi, if you status led become red and only that light is on must be 1 of the following problems:
1.- Front Cover is opened
2.- Memory Full
3.- Option Tray is installed too much
4.- Print Overun
Sep 13, 2013 | Brother HL-5370DWT Laser Printer
The error light is flashing red and I am unable to print.
Try to reset the printer by turning it off, removing the plug, let it sit for 5 mins ans plug it back again.
By the way, what is the model of the printer?
Oct 05, 2010 | Brother Office Equipment & Supplies
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Red and green lights flashing, won't print or respond to commands. Problem started when cleaning heads and subsequently testing with the print pattern. Monitor says a general printing error and suggests...
The heads are clogged. Unplug the printer remove the cartridges and dump them (never use the same brand of it or the same ink),pour some cleaning fluid there and leave it to soak. If you have some empty cartridges fill them with cleaning fluid and use them.
Oct 04, 2009 | Epson Stylus Photo 1290 InkJet Printer
Error 1
I had this, a small piece of label had got stuck behind the wheel, couldn't see it at first but with a bright light and a fine tweezers got it out. Check the drive wheel is turning if not you've probably got it jammed somehow. Also change the batteries, leave out a while and then replace. Also make sure the tiny lever on the top right is down (wont drive the tape unless down or the lid fixed back on)
Oct 04, 2009 | Dymo LetraTag QX50 Thermal Label Printer
The red light then all the other lights flash alternately- nothing will print
• Reset the printer by briefly turning the printer off and back on again.
• If the error persists, contact a service representative.
Sep 14, 2009 | Samsung ML 1430 Laser Printer
Won't print
Try turning it off then back on or press the button with the arrow on it
May 29, 2009 | Epson Stylus Photo R200 InkJet Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
