Question about Mitsubishi VS-55707 TV
WD-73733 Sound no picture, replaced lamp, still not working
    Scholar:
  • 63 Answers
I assume you were getting a code flashing on the front indicator showing a lamp problem? 34 code is common and indicates "lamp abnormality" If you are not clear on how to read the code I believe your owners manual has a section explaining that. If the lamp was blown it is possible the ballast board that provides voltage to fire the lamp is also defective and this may also give you the same error code. I would recommend also that you first reseat the lamp assembly to be sure it is fully plugged in. Also be sure the lamp door is postioned and secured properly (this typically will give a different error code, however) Also try unplugging the unit for a few minutes to reset and try powering it up again. Sometimes this will clear a problem.
Posted on Nov 12, 2009
I installed new lamp comes on then goes off and I hear a buzzing sound. Could it be that it's not installed properly for get light to come on. I had to use different screws because the new lamp didn't
How do you know the solution is "simple"? No always is simple. Bussing is high voltage missing. Like is bad conection to the lamp. Check conections of it.There is some bad about the conections of lamp. I guess.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
Installed new lamp but her static sounds wd-73733 and still no picture
I would venture to guess the bulb figment is your issue and the electrical sound is most likely arching (very bad). The cheap replacements won't last. I bought a sylvania build and matched the model number with the one from inside the old bulb housing. Changing out the bulb from the casing is really easy so just return the one you bought and buy the corresponding bul without the case.
My mitsubishi wd 73733 just made a popping sound and went off.when i tried to turn it back on its making noises with no picture goes from a green light to blinking red on lamp inicator do i need a bulb or...
You can actually go with just buying a bulb. I have seen many cases where televisions stopped displaying a picture due to a worn out bulb. The noise is also from the weak bulb.
Mar 13, 2011 | Mitsubishi WD-73733 73" HDTV
Heard a loud pop and now there is not picture
The first place to start is to remove the lamp and see if it looks ok. It sounds like the filament may have busted, which is common. How long has it been since it has been replaced?
Sep 03, 2010 | Mitsubishi WD-73733 73" HDTV
TV will not power on, strange arcing and poping noise from rear
Even though the Lamp looks good it does not mean that it is. The only way to know is to relace it. If you have already replaced it with a Mitsubishi Lamp Assy. then the Ballast board would probably be the cause.
Hope this helps,
Skyassoc
Jul 04, 2009 | Mitsubishi WD-73733 73" HDTV
Mitsubishi VS-55707 TV Logo
239 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
